I spoke to someone (Michael perhaps?) at VPW a week or two ago regarding those same bolts.
He told me he was expecting a 5week wait on them...
What was the name of the shop Takai? as I'm still chasing some for my setup.
Local speed shoppe here had a set of 4AG ARP bolts on the shelf, so while im waiting for the ones from VPW (still waiting) i got this set too.
Camera batteries were flat and my wifes camera doesnt have macro.
ditto
was planning on VPW - appreciate any news on where to get them locally, otherwise ill go OS
../delete/ban
tech moderator
The shop has one more packet in ed. Ill pm you the details.
lojik: ed has first dibs, then ill put it out far and wide.
i ebay'd mine already... fire away![]()
../delete/ban
tech moderator
Shoppe is Outlaw Speed Shop (http://www.outlawspeed.com.au/) They had one or two left in stock when i was in today.
Much appreciated dude.
I've fired them off an email.
I can't speak for all #JZ flywheel bolts, but those used on the 2JZ in the IS with a dual mass flywheel are plastic region type single use bolts.
What does ARP specify on those bolts?
No idea, ARP dont make the dual mass flywheel (v160) bolts.
std arp bolts are 58lbs with moly lube, 75llbs engine oil
../delete/ban
tech moderator
Thread Revival!
Looking for some slightly longer bolts to hold the flywheel on my 2JZ (as it's using the flex plate sandwich like my 1UZ is). I ordered some for the 1UZ from toyota last year, but I've lost the PN. I think it might have been a 3VZ bolt?
So 3 questions:
Does 1UZ use the 10x1.25 bolt as the 2JZ does?
Does anyone have the PN for these longer bolts (I think Cruzida had it originally)
And...are these bolts single-use TTY?
Thanks
-RM
Solved, thanks to v-eight.com!
1UZ-FE (auto) - M10x1.25 23mm UHL
3RZ-FE (manual) - M10x1.25 33mm UHL, Toyota Part # is 90910-02116
1/2JZ-GTE**/4A-GE/7M-GTE (manual) - M10x1.25 26.7 UHL, ARP part # is 203-2802
3S-GTE (manual) - M12x1.25
22R/21R/20R/18R (manual) - M11x1.25 26.2mm UHL, Toyota Part # is 90105-10030
-RM
I assume they are but it would be great if they aren't.
Does anyone know if there are any ARP equivalents?
JZA80 Supra Aerotop undergoing 3UZFE VVTi + Twin Turbos / Getrag 6 Speed conversion
