Results 1 to 5 of 5
Thread: Head/engine reco place in SA
    broom broom Automotive Encyclopaedia poida's Avatar
    Question Head/engine reco place in SA
    I am after some recommendations for a place to freshen up my 2tg twincam head in SA.
    I am not after a race spec head, just a crack test, change over of old seals, inspection and possible replacement of parts such as valves etc and a clean/acid dip if needed.
    I'd prefer someone who has worked on these heads before and also any ballpark figures on how much i would expect to pay on a basic freshen up.
    I will also get the block cleaned if they can do this.
    Thanks,
    Pete
    S.A
    Default Re: Head/engine reco place in SA
    yep i can help ya...
    call TW engineering...... its where i do all my stuff ... (mates own it) they can hot tank your block etc too..
    look em up in the pages... they are at st agnes
    dont have their workshop no....only his mobile
    Jun 2007
    Adelaide Cylinder Heads on Port road, is who I use consistently.
    Cost is usually very competitive, just get a quote over the phone and then drop of the Head that afternoon, as they sometimes do under-cut their set prices depending upon various factors.
    Knight Engines.
    (08) 8376 9540
    Tony will be able to sort you out.
    Cheers and + rep for you. I called them all and got some rough prices. There is a bit of fiddly time consuming work to be done with the shim under bucket style of head. I will go a couple of them and hopefully have it done sometime soon.
