Results 1 to 8 of 8
Thread: Crown Offset
    May 2007
    Lightbulb Crown Offset
    hi would anyone have any idea roughly wat offset i would need to run 17x7's on my gs131 crown? i took some measurements and it appears i only have about 50mm to play with from the hub to the lip of the guard that is the rear, didnt check front.
    any help appreciated
    waz
    Forum Sponsor Conversion King
    Default Re: Crown Offset
    if you want some simmons for it i believe "the stitt" has some on his 131 that he wants to sell, or he could give you the offset measurements.
    linden
    Act
    my UZS131 runs 17x8's with 0 offset.
    I am after some 9's and 10's with 0 and +10 offset
    May 2007
    thanks guys. i dont think my GS would get 0 in the gaurds. must be different to the UZ. guess its gunna have to be trial and error. thanks for ur time.
    waz
    Act
    that surprises me
    how did you measure them.
    My 68 Crown runs FWD off set +38 on 7inch rims
    50mm seems a little low
    thats all
    GS131, will run pre AU falcon offset. That is all you need to tell the wheel shop.
    cheers Chuck.
    MS51Crown Coupe,
    May 2007
    i measured with a bodgy straight edge and a tape measure in the rain could be a little more probly more like 60mm was bein a little bit tight arse just to ensure the rims tuck in if i can manage to go that low. pre AU huh. tempe says preAU is 5x114.3 +20. seems as though anythin should fit really. thanks for the info
    waz
    Act
    anything cheap will fit
    I'm having issues trying to find the 0 off set
  1. Toyota Crown MS53 Crown Custom Wagon
    By TheToyman75 in forum Tech and Conversions
    Last Post: 23-06-2011, 11:44 AM
  2. Wheels and offset for TA22 with "F" series diff
    By "Z" UTE in forum Tech and Conversions
    Last Post: 28-09-2007, 12:58 AM
  3. 79 Crown question.
    By Danger in forum Tech and Conversions
    Last Post: 08-05-2007, 08:17 PM
