Results 1 to 3 of 3
Thread: RT 142 diff replacement.
    Junior Member Grease Monkey Mr Multivalve's Avatar
    Default RT 142 diff replacement.
    My current diff is close to completely dying it started screaming and i could smell burning the other night.
    I am set up to swap it over but I wanted to know regarding the removal of the diff. Is there enough play in the drive shafts going to each wheel to get the diff out. Or do I have to unbolt the rear control arms(not sure if that is what they are called) to get some horizontal play so I can pop the diff out.
    If anyone has done this and has some tips I would appreciate it as I plan on swapping my diff over on friday or the weekend.
    Thanks
    Corona Creed:
    Good to Drink, Great to Drive, keep them separate to stay Alive!
    Default Re: RT 142 diff replacement.
    IRS or live axle? I found the easiest way to remove the diff in an IRS corona is to unbolt the whole rear subframe from the body. There will be some bolts on the bracket above the diff and the crossmember under the back seat. The bolts for the crossmsmber are accessable when you remeve the back seat. Its the easiest way rather than fighting to undo the diff mount bolts themselves that will be caked in shit and be hell tight and have shit access. Just make sure you disconnect both brake lines before you lower rear subframe down.
    Ok cool thanks for the help pube. It is IRS of course.
    Corona Creed:
  1. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  2. changing the gear ratio's in hilux diff.
  3. diff pinion seal replacement ke20/25
    By RO11LR in forum Tech and Conversions
    Last Post: 31-05-2006, 02:38 PM
  4. Diff Question
    By mlaser in forum Tech and Conversions
    Last Post: 17-04-2006, 08:13 PM
