Most JZ compressors appear to be interchangeable, at least in their mounting setup.
The caveats are pulley size, body size, hose fittings. Aristo compressors appear to be larger in diameter, which puts the top plate higher up and closer to the power steering pump, potentially causing clearance issues. Not sure about atmo 2JZs...
So the answer is quite possibly, but you'd probably have to try it.
Mos.
