search and ye shall find!.
5 stud conversion can be found in the corona/pug/hiluc coilover conversion thread,
again, search.
Blake![]()
				ok finally with the death of my 18rgeu, i am doing my celica up. going to put a 1ggte in it, but atm i am in the planning stages, at the moment i am chasing 1gge engine mounts but i cant find any listings on them for new. does any one have the part no for them. also, just after a tech article on the brake upgrade to 5 stud. i am just in the planing stages for the parts and how to do some stuff.
again, search.
Blake![]()
telling us type of celica also helps. eg. ra60, ta22 yada yada
				sorry thought i stated it, my bad, its a ra23, welll its plated ta23
				there are about 10 threads that come to mind but i dont know how to do links so try the search function or ppls members rides threads.
linden
Originally Posted by WHITCHY
				i am not a big fan of this search, i do that and dont get the info i need
i've heard you may be able to get the mounts needed new, but for like $250...altho thats just a rumour i heard. Best off finding some used, there used to be some for sale on here but dunno if they sold or not. Remember to get ones off a ga70 or gz2-, as gz10 ones look the same, but are slightly different, and need more mods.
1977 RA23 Celica -> 1ggte conversion [SOLD]
MA70 Supra 1JZ 5speed [SOLD]
Current: IS200 1JZ VVTI 6 speed
Hey buddy do you still have the TA23 x member in you car or has it been changed to an RA23 item when the 18R was fitted?
If you still have the TA23 X member you will need a frount sump 1G and leave the engine mounts in the foward position.
This is a bonus caus you dont have to re drill the mounts or cut the web(you can do one or the other or a combination of both). But you still need to space the drivers side mount and change the angle of the passenger side mount.If using GA70/GZ20 1GGTE muonts.
The TA23 X member is the best option to use when fitting power steer to.
Hey i know what you mean about the search the info is here but it can be hard to find at times.
Good luck
Cheers Case
OT: wut happened to ur car case??
This link should have plenty of info on 1GGTE build up. Maybe that will help![]()
Good luck!
http://www.toymods.net/forums/showthread.php?t=5909
Black Betty >HERE!<
(\__/)
				thanks guys, i may have sorced a 1ggte
Make sure you pick up a half-cut , if you buy just the motor then you will need to track down all the other parts which will take time & cost more that the half cut.
you can re-use the Master cylinder and windscreen wiper from your half cut.
Make sure you pickup a GEN 3 motor, the best way to tell is the "1G" is stamped at the side / back of the motor.
				yeah hunting around for a gen 3 as my the one i had linned up was sold on me
				Hey kristian,
I may just be convinced to sell the 1GGTE I bought for my RA23. No time and energy for a conversion of this nature at the moment.
message me.
Dave
You would also take a look at the 1G-FE motor & gear box from a IS200..
As they are being imported now & come with a 6 speed gear box..![]()
When doing my homework on this 1Gxxx motor up grade here in Adelaide, i was told that with the 4 stud, & size of rotors, i could fit a motor up to 190hp, But had to go to 5 stud if over.. ( this was a general thing & may not be for all.)![]()
So i can fit a 1GGE,1GFE, or 1GGZE, but not the 1GGTE...
If i didn't already have my motor & g/box, i would look at the 1G-FE & 6 speed g/box...![]()
it all comes down to the $'s you want to spend..
I work on a budget & have to have budget hp & brakes..![]()
Project: '82, GA61 XX
