Check to see if you have a hairline crack in the mount. You need a hoist and a strong light. If you need to lower or change spring rate buy a pair. Cost is 150- 250 dollars. Springs fatigue over time and loose their hardness. Choping springs is illegal and stupid. Also check bushes and all steering joints. If you can't find the problem take it to Pedder's Suspension for a 28 point safety check. Only $14. They will check front and rear shock wear rates, All steering and suspesion and give you a written report. What you do next is up to you. Definately find the cause of the problem.![]()
