Results 1 to 10 of 10
Thread: 7mge rough when cold
    Junior Member Grease Monkey supra_cam's Avatar
    tasmania
    Default 7mge rough when cold
    For the last couple of weeks my 7mge has been driving rough when cold until it reaches its normal driving temperature then its suddenly drives normally. Not really sure where to start looking? Its not bothering me too much at the moment but I would rather check it out incase it gets worse.
    Apr 2007
    Default Re: 7mge rough when cold
    Maybe try checking for codes, and possible coolant temp sensor, rooted
    7mge's have a cold start injector, id check that ;-)
    RA23 - Twincharged
    JZZ20 - Daily
    worships the 2JZ (GE lol) 1st year Apprentice uncivilised's Avatar
    My cressy did this when it was auto. As soon as i converted it to manual this went away. Strange.
    SO00RA Domestic Engineer 4agerolla's Avatar
    My 7m(gte) did this, then I realised it had a BHG So that may be a possibility!
    - Silver 2012 Lexus ISF - 2UR-GSE 5 litre V8 goodness
    - Black JZZ30 Soarer - 1JZ-GTE VVTi + factory R154 manual
    - Blue KE17 Sprinter- 3k + K40 manual
    - White MS55 Crown - 2M + 4 speed column shift manual
    - Blue MS51 Crown Hard Top - Angry 4M-B + W50 manual
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    BHG!!!for dure mine was the same
    If the engine is also hard to start, yes I would look at the cold start intector time out switch. If it starts well, then you have other problems.
    cheers Chuck.
    MS51Crown Coupe,
    tasmania
    I doubt its a bhg, i've already fixed that crap. Ive checked the codes and it comes up with the TPS, but i'll also check that cold start injector and coolant temp sensor, thanks for that. My mate thinks it may even be the fuel filter? Hope not, 'cause there in a bit of a tricky spot to get to!
    Jun 2007
    Its definitely not the Fuel Filter so don't waste your time or money on that.
    May 2007
    tasmania
    you did the hg but did you use arp studs and metal head gasket?
  1. 3s-fe cold start problem
    By neon in forum Tech and Conversions
    Last Post: 15-11-2007, 10:53 AM
  2. 4ag running cold
    By bmak in forum Tech and Conversions
    Last Post: 01-10-2006, 08:19 PM
  3. Wobbly steering under braking when cold
    By Ta2272 in forum Tech and Conversions
    Last Post: 07-02-2006, 10:59 PM
