Results 1 to 7 of 7
Thread: Thoughts on turbo blankets?
    TAS
    Question Thoughts on turbo blankets?
    For:
    Reduces under-bonnet heat, protects nearby components from heat damage
    Against:
    Cooks turbo?
    Any thoughts on these? The KKR-430 will be close to my clutch & brake masters and I need to shield them somehow. I'm concerned about reducing turbo life or other problems associated with the turbo being baked though.
    Default Re: Thoughts on turbo blankets?
    In reply to:
    For: You can achieve this by shielding the individual components as neccesary.
    Against: With adequate cooling to the water and oil supply of the turbo you shouldn't be at much more risk than the factory heat shields they use on some turbos.
    There was a good thread on this a while ago, see HERE
    Phil
    coat, bag and shield...easy
    TAS
    LOL
    I had one on the T28 on my 4AGTE for about a month, it obviously did a good job of trapping the heat cause the exhaust housing had a blue tinge afterwards Downside was that the 8mm studs for the dump pipe kept snapping. Removed the turbo bag and no more breakages. And no, they weren't garden-variety cut offs from threaded rod from Bunnings either
    Brisbane
    Make sure you have a fire extinguisher.
    I've seen one of these catch fire before, and know of someone who also had the same issue.
    Last Post: 03-05-2009, 06:47 PM
  2. Turbo Heat Shielding
    By MarioM in forum Tech and Conversions
    Last Post: 21-05-2007, 09:18 PM
  3. 7m-gte turbo leaking, need help...
    By shaun185 in forum Tech and Conversions
    Last Post: 05-01-2007, 07:58 PM
