low imp run in series with the resistor. and high imp don't need the resistor block
if you tie the wires together, you are effectively shorting it out... ie, the input to the two output wires..
you may as well just remove the block and solder the wires together, or set up a connector from another resistor to bridge back... so you can still use your current one if you want.
