Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: 2JZGE Wiring Diagram?
    Default Re: 2JZGE Wiring Diagram?
    Shrugs, no idea. This is the electrical manual, it doesnt really deal much with the gearboxes. Just notes that the V160 reverse plug is different to the R154 and W58 plugs.
    Mos: any luck?
    Luck? Yep
    With the diagrams i meant
    Oh that... err not yet...
    Hehe, im figuring i only need a handful of the wires. Going to check tonight if they match up. Because they are the critical ones.
    Lastly who knows what the "Acronym" pins are.
    "MI"
    "DI"
    "TS"
    "WA"
    MI = Manual Indicator Light, +12V via 120A ALT Fuse, via 40A AM1 Fuse, via AM1-IG1 (Ignition Switch), via 15A GAUGE Fuse, via MANU indicator light, via ECU NPN to E? (GND), active low = MANU indicator light ON (From GS300 wiring diagram)
    DI = Fuel Pump ECU Diagnostic Line, Active low / open circuit error (Fuel Pump ECU has PNP transistor to +B), ECU internal pull down to E1 (GND): Normal Operation Fuel Pump ECU connects to +B (If DI < ~7.5V FPC PWM Output to Fuel Pump ECU does not PWM).
    Yeah, i had figured those ones out.
    No FP ECU here, hence just rewiring to hold the FP on when the ECU is on, a la the AE92 setup.
    No auto box either, hence no need for MI, and indeed no auto transmission pins at all.
  1. 2jzge Vvt-i Wiring
    By teamdrinkalot in forum Tech and Conversions
    Last Post: 02-12-2008, 07:24 PM
  2. 4agte wiring
    By pro-16t in forum Tech and Conversions
    Last Post: 25-08-2007, 10:04 AM
  3. 2jzge eng wiring loom
    By gtz1 in forum Tech and Conversions
    Last Post: 26-11-2006, 08:58 AM
  4. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 11:27 AM
  5. 100kW 4AGE wiring diagrams
    Last Post: 15-04-2006, 06:03 PM
