Q1 - No idea. Don't quote me but I think that the rwd waterpump does come with the right back housing you will need. You will still need the inlet housing that has the thermostat
Q2 - Yes bolts onto my 100kw no problems
Q3 - If you use the rwd waterpump you must use the rwd waterpump pulley so that it lines up with the main crank pulley. You can use the fwd waterpump and fwp pulley with the rwp backing too if you are using a thermofan
Q4 - You will need the metal lines running from the rwd waterpump to the rear of the head. Also for the 100kw with the external oil drain from the head the rubber drain pipe interferes with these metal pipes in the stock location. I think you can rotate the fitting in the block so that it points away from the metal pipes and you will be right. I can take pics of this if you need as I need to see if this will work for me as my motor is still pulled down. Also as you mentioned the alternator brackets must be modified to make the alternator lower or use the rwd alternator brackets.
