ok please note this info relates to a soarer (z30 series) so it will either help you or not be of any use at all.
if there is moisture in the lights to begin with it will just evaporate and fog up as you mentioned when a bit of heat is applied in the 'sealed' cavity.
What i did was to go to the supermarkets to get a product that removes moisture from the air. Normally it goes in the back of a linen cupboard or something to remove moisture and mildew. it comes in a container of little white powdery beads and doesn't cost any more than a few bucks (in the laundry cleaning section of your supermarket) i think it is like the silica gel you get in lots of packaging to avoid moisture in the packaging.
Chuck that container in a box along with a light and seal the box up with sticky tape.
chuck the box under a heat source to help the 'drying process (a good hot sunny day will do or a desktop lamp or something), then at the end of the day it should be nice and dry on the inside.
the soarer's lights has 2 vent holes at the back. i found that if i put the globes into the lights in and blocked off one of the 2 vent holes and blew into the other one that it was indeed sealed, if i got a leak, it was around the lense area and i just put a bit of silicone in that area.
once that was all done, i never had an issue again with fogging lamps.
each light only took 5 minutes to prepare, but i had to wait the day per light for the moisture sucking thing to do its bit.
Note it used to also condense up after a rain shower or car wash but it doesn't do that now either.
