Results 1 to 3 of 3
Thread: TA22 strut brake upgrade/5 stud conv
    Apr 2007
    Default TA22 strut brake upgrade/5 stud conv
    hey guys, got some modified ta22 struts to put on my ke26, currently they just hav the standard celica brakes on them. i have a pair of rebuilt 4-pot rx7 calipers lying around which i wouldn't mind chucking on the struts. has anyone done this before? how would i go about doing this?
    also i want to change from 4 stud to a ford 5 stud pattern, what would be the best way to do this?
    cheers for any help.
    Junior Member 1uzfekp60's Avatar
    Sep 2007
    NZ
    Default Re: TA22 strut brake upgrade/5 stud conv
    I changed a corona 4 stud to 5 using a hiace hub with some sleeves made to fit over the stub axle to increase diameter for hiace bearings. No welding on the hub, just a little machining for the bearings and hat type disk on.
    Ken.
    Junior Member Backyard Mechanic sleeektoy's Avatar
    Jan 2007
    Auckland
    There was a guy here in NZ that fitted series 4 RX7 4 pots to his RA28 - he made up new backing plates for the calipers to bolt to. I think there was a wheel size issue - had to have 15 inch wheels or bigger for clearance.
    _____________________________________________
    TA27 GT - How rare can you get!!!
    RA28 GTV daily driver
    By The Witzl in forum FAQ
  2. Replies: 97
    Last Post: 30-01-2006, 11:43 PM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
