Results 16 to 21 of 21
Thread: 4AGE oil pump
    Tallahassee, FL USofA
    Default Re: 4AGE oil pump
    If it's a hollow one, a tap or wood dowel can be jammed into it.
    Inerita should get it out, by hitting the housing in a direction against the way it needs to move out, hitting toward its seat, in the direction of its travel, should back it out if it isn't too bad or smegma'd up.
    After cleaning up the valve & bore, it should slide freely and drop out of the bore on its own, with maybe thin lube & a little shake.
    Hoppers Crossing
    i'll try air pressure first and see how we go
    i've tried the gentle tap method too to no avail
    not keen on drilling a hole in it, but good suggestion
    AB
    have you removed the retainer (part #15135 from diagram). I had some problems getting mine apart to clean and found that i left the retainer in there, once removed it all came tumbling out.
    if its jammed, its jammed, you can find new pumps all over the net from $5 and up.
    edit: nevermind, i've been speed reading too much lately gotta slow it down.
    Quote Originally Posted by merc-blue
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
    S.A
    Quote Originally Posted by Grega
    Got the circlip pliers out to find a spring, a hat and a little enclosure it sits in with what looks to be a piston at the top with a relief valve or two in it
    from the first post.
    Hoppers Crossing
    air pressure for the win
    i rigged up some fuel hose to my air compressor air gun and pumped air gently into the main hole blocking the other holes with my fingers and she popped out no problem
    getting the thing back in and cleaned - no probs
    getting the circlip back on - 1 hour later no probs either :|
    Hoppers Crossing
    here you go, this is how i did it
    results speak for themselves...........(piston at the bottom see)
  1. HELP - how to wire up a fuel pump
    Last Post: 21-06-2007, 12:15 PM
  2. 18RG oil pump driveshaft
    By Damo82 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:36 PM
  3. 4age fuel pump for 4agze
    By dug in forum Tech and Conversions
    Last Post: 30-06-2006, 07:10 AM
