Results 1 to 15 of 16
Thread: Can you use a petrol tubro on a diesel?
    Junior Member Backyard Mechanic {Mr Crabs}'s Avatar
    Apr 2007
    Default Can you use a petrol tubro on a diesel?
    Hi every one
    One of my mates asked me what i was doing with the stock turbos of my 1G and could he put one on his Hilux 2.8D. I know you cant put a diesel turbo on a petrol engine. Any help would be good .
    Cheers Case
    Default Re: Can you use a petrol tubro on a diesel?
    does diesel have larger exhaust housing?
    Ouch, 1 turbo from a 1ggte on a 2.8L... :S
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    1psi of boost
    Seems pretty pointless to me. Don't they run out of puff, with the pair of them, on the 2L 1G? Let alone a 2.8.
    Diesel revs are a lot lower though, so flow-rate would be a lot lower. Large capacity + low revs = small capacity + high revs
    True, but I still think a turbo designed for 1 litre of petrol engine still won't be up to the task. Also remember diesels typically like a larger exhaust housing than a petrol engine of similar power output, so that little CT12 will likely choke it.
    edit: forgot to read original post fully, stupid alcohol
    should spool well
    i think he means BOTH turbos,
    probably be alright with the twin setup on it,
    but why would you waste money on that, when you could pick up a t28 for $2-300 and be easier to fit, more cost effective,
    ct12s are good for the bin!
    Quote Originally Posted by case
    No, he didn't say anything about putting both on. I agree with both it might work sort of OK, but just one definitely won't.
    Junior Member Domestic Engineer Hurricane's Avatar
    best way is to slap it on. and if it doent work sell it for what ya got it for? thats if you can make your own mainifold?
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    Apr 2007
    I ment use one or both,a hilux surf has one Ct12 on it.
    Making a manifold would be no problem,and yes the CT12 are worthless to me.
    So it might work but he is better of geting a turbo to suit his car and go from there.
    Cheers Case
    the 1kzte off the top of my head has a ct12a turbo on it. dont know about different exhaust housing sizes but it certainly is a tiny turbo. and thats on a 3litre.
    remember you also want it to be boosting at 1200rpm no point in having diesel that isnt on song until 3000rpm. even on my petrol hilux it spends huge ammounts of time under 2000rpm when in the dirt.
    Junior Member Domestic Engineer NeoNasty's Avatar
    I was wondering about diesel turbo Vs petrol turbos too and their requirements.
    Obviously diesel you want it spooling as early as possible, so you have a.. larger?.. exhaust turbine?
    Is there any sort of general system you can use, ie. a 2 liter petrol engine turbo would be fairly suitable for an 3 liter diesel?
    Sure diesels only rev out to 4000RPM, but they also run leaner, around 18 - 21:1? therefore more exhaust flow?...
    Sorry for stealing the thread, I just thought maybe someone could add something that may help everyone.
    HZJ75, RS41, JZZ30
    Quote Originally Posted by NeoNasty
    Stoich AFR for diesel is pretty similar to petrol. They have compression ratios around 18-21:1 though, maybe you're getting them confused.
  1. Opinions requested re : Diesel Vs Petrol engine
    By greywolf in forum Tech and Conversions
    Last Post: 15-01-2008, 07:04 AM
  2. mate put petrol in a diesel... what now?
    By lojik in forum Tech and Conversions
    Last Post: 23-01-2006, 02:11 PM
