Depends if your current external pump is original from factory, or has been replaced at some stage. The original external pump in the VL was different between turbo & N/A, but the bosch replacement listed in the catalogue is a generic pump (call it VL turbo) that is used for both. This pump will supply roughly enough for 250kw at the wheels.
If you plan mods for more power later, then upgrading the external pump to a larger bosch unit (even as big as the 600hp 044 if your target requires) is easy enough, still with the standard setup (intank helper pump, but no surge tank), or go for a boot mounted surge tank straight up if you have concerns about starvation with low fuel/long corners.
With the surge tank you could still use the factory in-tank pump as your lift pump, provided that the return line from the fuel rail goes back to the surge tank, not the main tank.
