Results 1 to 7 of 7
Thread: reading torque curve on dyno graph
    Default reading torque curve on dyno graph
    hey guys,
    finally got my car re-dynoed today to check my AFRs are all good.
    They are and it pulled a healthy 169kw @ 10psi. AFR started at 14.7 and trailed down nicely as boost came on.
    Thing i cant understand is what scale the torque curve goes off? The scale on the right cant be RPM as it doesnt line up with the speed i actually go in 4th (ie at 100kmh in forth im doing 3.5k not 4.5k)
    It does have a N on it, but i dont think its netwons...............
    Thanks for any help.
    Nathan
    PS car is a ma61 with a 1jzgte. All stock except zorst and front mount.
    Junior Member Grease Monkey 3BarSuperstar's Avatar
    Nov 2007
    Default Re: reading torque curve on dyno graph
    I think it is newtons from memory. Maybe ask the guys where you got it dynoed!!
    Nm for tractive effort
    If in doubt power out
    rona your spot on its tractive effort
    found a formula on the net to convert it over to NM
    booya!
    Quote Originally Posted by naten
    Got a link or want to post this up? Would be interesting to know...
    They ran it in N/A mode instead of FI but will not make much difference to overall result.
    Just one of my little pet hates.
    Prefer to see the A/F ratios on the graph instead of torque as you can always work that out from the data.
    Linky for formula:
    http://www.webster-inst.com/techinfo...qnfr/eqn17.htm
    Bit more of a explanation:
    http://www.skylinesaustralia.com/for...rt-t79685.html
    So for my car its peak tractive effort was around 4500
    Run that through the forumla it equals 326 ish nm
  1. Weird dyno graph, does anyone know what it could be?
    By Mazman in forum Tech and Conversions
    Last Post: 23-10-2007, 12:27 AM
  2. Thoughts on this dyno graph, is my power being restricted?
    By -==L=a=N=c=E==- in forum Tech and Conversions
    Last Post: 23-01-2007, 02:11 PM
  3. Dyno Day 12.5 - Saturday 21st Jan. - Show of hands?????
    Last Post: 28-01-2006, 12:38 PM
  4. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 10:46 PM
