Results 1 to 2 of 2
Thread: Gen1/3 cams into Gen2 3S-GTE?
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    Default Gen1/3 cams into Gen2 3S-GTE?
    Gen1/3 cams into Gen2 3S-GTE. Just checking, is it do-able? Presumably you would need way thicker shims...
    is firing on all eight. Carport Converter AndyTTR's Avatar
    Default Re: Gen1/3 cams into Gen2 3S-GTE?
    I believe you can put Gen 3 cams into a Gen 2 if you use the Gen 3 shims and buckets (which is also another upgrade seeing as the gen 3 runs shim-under-bucket rather than bucket-under-shim like the gen 1/2).
    If you search for info on the shims you might find the info you need about the cams.
    Hope this helps.
  1. [warning] TRD 272degree cams for 4age
    By progkamol in forum Tech and Conversions
    Last Post: 19-07-2006, 09:48 AM
  2. Whats the diference between these 7m cams?
    Last Post: 18-01-2006, 03:15 PM
