Results 16 to 19 of 19
Thread: TA22 Air Con Installation
    Default Re: TA22 Air Con Installation
    nope - mine's just a simple temp sensor that turns a 12V relay on/off. you'd also need a TPS of some kind for that kit.
    Well got some bits of Charles last night, and looks like mounting the compressor he gave me will be pretty easy! All ive gotta do is hack up the bracket he gave me with a grinder until its just a flat plate with the compressor mounts on it, drill some holes and mount it to the backet that mounts to my engine, which has the idler pulley built into it and just make sure the compressor pulley lines up and it should be sweet! Plus its much smaller than the TA22 one, and should be ready to go with the new gasses by teh sounds of it. So will start hacking tonight hopefully!
    With the pipes, do you just screw them straight on or is there any special thread sealant they use so they dont leak?
    Toyota Car Club (Qld)
    they are supposed to have O rings that go on them, and they need a special lubricant on them... you shouldn't apply them dry
    I am the sun
    Apparently I'm a Backyard Mechanic PULSE's Avatar
    Hey guys, anyone know what a TA22 air con setup is worth? Not including the compressor, just all the bits in the car.
    Cheers, Matt
  1. strut brace for a TA22
    By ca_celica in forum Tech and Conversions
    Last Post: 11-04-2014, 11:55 AM
  2. ma61 diff in a ta22?
    By weapon x in forum Tech and Conversions
    Last Post: 20-04-2006, 12:25 AM
