A couple of things... first is how low is the compression?? This could be a big factor, and your mate with his 4A could be running much higher compression, which will give better off boost torque, and faster spool.
Second, did you have the turbo tested before installation?? It could be a dud turbo.
Third, how good is your tune?? Especially spark curve. Was it done professionally, is it something your personally capable of doing (using a wide band oxy sensor of course), or did you go for near enough is good enough??
Fourth, its a turbo designed for a 2Ltr, so it will be a touch laggy, did you balance the motor when you built it?? In which case you should be able to open up the top end, which is where it will work.
There are soooo many variables, you need to document exactly how the motor was built, and even some screen dumps of the ECU maps would be nice.
