Results 1 to 7 of 7
Thread: Help needed, Hilux Diff Ratio how to Identify
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Default Help needed, Hilux Diff Ratio how to Identify
    Hi guys,
    Im looking at a Hilux diff cant find the 4 digit ID But have found the number 61Y on the unit.
    I know the unit is from an LN60 2.4D 1410 drum to drum.
    How Can I find what the diff ratio is with out the 4 digit ID?
    and is the 61Y meaning full?
    Manny
    Forum Sponsor Conversion King
    Default Re: Help needed, Hilux Diff Ratio how to Identify
    count the teeth? thats the accurate way of doing it. what if someone swapped a diffent ratio to std in there? diff codes dont really mean much unless its 100% stock.
    linden
    has no Toyota anymore :( Conversion King tooch's Avatar
    Will probably be a 4.3 ratio if its a diesel LN6x.
    But yeah the only other certain way really is to count the teeth.
    Nov 2007
    N.S.W
    Thanks guys,
    Did an esstimate before I picked up the diff, turned the yoke 2 and a bit times before the drum turned once , I was holding the other drum steady.
    Worked out to be about 4.4 ( multiplying by 2 as only 1 axle is turning).
    On getting the thing home I counted 39 teeth crown 9 teeth pinion (39/9 = 4.33)
    This should be close enough to the original final drive with the new box.
    Old (W50) 5th gear 0.85 Diff 4.1 final drive 3.485
    New (W58) 5th gear 0.783 Diff 4.33 final drive 3.39
    Anyone think otherwise?
    (Motor is a 1GGTE).
    Manuel
    4.3 should be spot on for a 1g but it may prove to be too short for extended highway use.
    what size tyres are you running? if its close to 620mm dia you will probly find that at 100kph you will be doing arund 3200rpm or so.
    linden
    Nov 2007
    N.S.W
    just measured up my wheels about 620mm (stock) which works out to110Kph @ 3200RPM ,and a top speed of 245Kph @ 7000RPM, that's only on paper dont really know if it will actually do that speed, would be interested to know if anyone has seen these speeds on the race track with this combo?
    what would be the largest dia tyres I could use under the RA28?
  1. My Hilux Diff. WTF?!
    Last Post: 14-08-2007, 09:17 AM
  2. Hilux diff ratios.
    By wheel rim in forum Tech and Conversions
    Last Post: 30-07-2007, 07:01 PM
