Results 1 to 7 of 7
Thread: SA63 engine cross member in an MZ11 will it fit?
    Drift barge master Backyard Mechanic orestes's Avatar
    Queensland.
    Default SA63 engine cross member in an MZ11 will it fit?
    As per post, I'm just wondering.... the main difference is the length of the nose otherwise celicas, aren't that different to supras. So it may sit a bit further forward then what you'd like, but would it an SA63 cross member fit?
    Just a stroke of genius in possibly fitting a 3S into a Soarer...
    MZ-10/GZ-10 hybrid turbo rolling shell, RB30 powered
    IS200 - 1GFE
    New Zealand
    Default Re: SA63 engine cross member in an MZ11 will it fit?
    Steering rack at least is on wrong angle (tilted back more on M version), may be other issues as well.
    Callum
    Won't fit. The front end is actually quite different in the Celicas, it's not just sheetmetal differences.
    Low Down Style Domestic Engineer Johnzoku's Avatar
    queensland
    cut the engine mounts off the soarers xmember and like wise on the sa63's and swap it over... then jsut use the 3s engine mounts. the steering rack is also on the other side of the xmember compaired to the soarer.
    also i have a spare mz10 xmember if your keen to do so.
    Forum Sponsor Conversion King
    Dec 2006
    hope you like having 6" of firewall clearance unless you go dry sump.
    the severe lack of low end torque with a 3s will leave you asking why you bothered.
    trust me when i say a 1j or similar will be cheaper and leave a bigger grin on your face once the conversion is done.
    linden
    Yep, 1JZ makes a lot more sense and will actually be fast.
    User Conversion King
    NWA
    ill have a guess and say the centre of the engine will be sitting directly over the xmember.
    sumping will be a bitch
    even if the xmember fits, it will probably be in line with the crank pulley.
    im going through the same issues with a 3RZ, and its longer.
    for ease and cost, go with a JZ. ive done a 2JZZ12 now and wilbo is halfway through his 2JZZ12 swap. plenty of info and guides around now
    hello
  1. Idiots guide to a 1jz conversion into a MA70 bodied supra.
    By Xistant in forum Engine & Driveline Conversions
    Last Post: 12-07-2019, 05:11 PM
  2. Sams MA61 7MGTE Conversion Guide
    Last Post: 07-07-2015, 11:12 PM
  3. MA70 --> JZA70 Conversion
