1.
1940cc is the "2 Litre" setup using the 3t crank at 78mm and
3t 89mm off the shelf pistons.
you can go:
90mm custom pistons apparently if you resleeve or grout fill but its very expensive,
some 3tc drag racers in puerto rico do this. for NA or turbo applications.
89mm off the shelf is only recommended for NA applications, results in thin walls.
88mm custom for NA or turbo applications.
87mm is the next off the shelf avaliable size for NA or turbo applications.
however if you have many 2tg blocks and can ultrasonically test the bores
then you might find one that is suitable for a safe bigger overbore than
recommended or you can offset bore the block if its suitable.
however, its not just breaking through the walls that you need to worry about,
its the bore distorting from a thin wall that can also be a problem with loss of
compression, losing more power than the mm extra overbore made.
you need to use the 3t crank and pistons as a combination, you cant use
2tg pistons. this is due to the stroker setup, 2tg pistons on a 3t crank are too
high and would smash up into the head.
also concerning 3t pistons, their compression ratio stated is for a 3t motor
which has a bigger combustion chamber volume 63cc i believe, whereas
a 2tg motor once the head is skimmed flat has only about 52cc. this makes
a big difference when doing compression ratios and check what fuel octanes
are avalaible. get your head chambers cc'd with a burette before buying pistons.
3t turbo pistons are way lower compression but are too low for big cams.
big cams need big static compression reading which with a big cam will
result in decent dynamic compression ratio.
the 3t pistons have to be flycut to clear the valves, aftermarket 3t psitons have
an oversize valve reliefs and dont need to be machined as far as i know,
always check first though.
2.
quad throttle bodies will be ok, it would be a custom set or use weber dcoe carbs as
the throttle bodies with injectors and managment.
3.
aftermarket management is very good provided its tuned properly.
you can go semi diy or full retail setup. remember tuning costs a lot too.
4.
extractors and exhaust fine, many brands of extractors. dont go too big on
the exhaust, you can use some calculations to design an exhaust system for you.
go mild steel pressed, stainless steel mandrel is expensive for what you get.
5.
a set of cams that go past 8000rpm?, id say a set of 320 deg cams
should go from 5000 to 8000+ with a very rough idle and poor drivability but
it does 8000rpm+. not for a daily street car, it would be a pig to drive.
6.
power? with something from the above gear, about 120kw or 160hp at the fly.
2tgs arent dyno queens, they are in lightweight cars with good handling,
and as such, its not all about the peak power, but how you get there that counts.
