Hey dude
Would be good to see a power run with the boost controller either switched off or removed from your wastegate control. Its probably not relevant but with a hi flowed stock Turbo I would see boost creep up to 12 psi at redline.
What boost settings are you running? WHen I first had my car tuned the boost was spiking alot on the dyno but after playing around with the AVC-R or it learning things seemed to settle down. You will probably always get a bit of a spike when uppig boost on the standard turbo.
Is your wastegate actuator shimmed?
