Results 1 to 15 of 20
Thread: KONI or KYB AGX? advice needed,
    Default KONI or KYB AGX? advice needed,
    hey guys,
    im in a bit of a pickle
    ive just ordered some KONI adjustable inserts for a SW20 mr2 rear's, (for the front of the celica in XT130 coilover setup, )
    BUT, theres NIL stock in AUS, and will have to come from HOLLAND, 6-8 WEEK WAIT!....
    they have KYB AGX adjustable in stock, theres only a $20 difference between the KYB and KONI....
    price is not the problem, im trying the get the car together and ready for Dubbo.
    so how do you guys rate the KYB AGX's compared to the KONI's?
    all advice and info appreciated
    cheers, Blake
    senior backyard mechanic Grease Monkey legend's Avatar
    Default Re: KONI or KYB AGX? advice needed,
    koni thats it
    The Koni's are far better from what I have heard. Try orderring them from www.twosrus.com, most people seem to get their gear in about a week from there.
    Tasmania
    I have had both and I thought the KYB's were less harsh and easily adjustable. I don't think you lose anything by going KYB and I'm choosing those for my MX83 instead of Koni's.
    Quote Originally Posted by Joshstix
    i'll have to get in contact with them!
    I've got KYB AGX in the front of the celica (sw20 like your plan) and Koni yellows in the rear.
    After 5000km or so the KYB are going great, easy to adjust, good range of adjustment. The koni's are making some bad noises. I'll be replacing them for KYB AGX in the near future.
    My vote is for the KYB.. But each to their own I might have just been unlucky.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    im so stuck inbetween atm,
    i'll be doing some searching tonight, see what i can come up with, i honestly havent heard anything bad about the AGX, first hand,
    ive tried avery bloody susp stockist in NSW, and a few other around AUS, getting the same answers, 6-8 weeks
    I bought a full set of koni's once. But after developing leaks within about 10,000kms I won't be buying konis again.
    Hachi Rusto Backyard Mechanic Julz01's Avatar
    Ive got a set of kyb agx from a st185 to put into my ae86 struts chose them over the koni yellows for the fact that they are alot easier to adjust rather then having to compress the shock and then turn them , just easier to adjust from the top of the shock shaft.
    I've had my koni reds for a few years now, absolutely love them, and absolutely no issues whatsoever.
    Plenty of track days, several a year. Rate them as one of the best things i've done on the car. And they're externally adjustable, easy as. No kyb experience so you'll have to listen to other people's praise for them, and decide what's most important to you. With minimal price difference i'd be jumping at the koni's, but can you wait?
    Toymods Club Member
    had konis for a bit over a year now... coupled with anti-sway bars and strut braces, makes the car handle a lot better than stock.. i'm using progressive rate springs with them
    with the leak issue, i've heard that some springs (stock or chopped) are not compatible with koni adjustables, but this is just what i've been told.. then again, nobody i know uses stock springs with them and never seen anyone of them leak (except from a smash, which rooted everything under the car)
    TAS
    I have those exact AGX inserts (rear SW20) in my coilovers. I rate them.
    If only they made AGX shocks for more models...
    AB
    ive got koni yellows with intrax springs on aw11, im very happy so far (6months) its been said before but its sure nice to be able to adjust so easily.
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
    Forum Sponsor Conversion King
    Dec 2006
    id be going for koni,
    what about the bump and rebound adjustable version? like MWP has?
    call topper performance in melb, they will be able to sort you out for sure.
    you going to dyno day? let me know if your not coz ill make the calls next week to sort it all for you. fuknsobusyfukn
    linden
  1. Aftermarket 2-Way/1.5Way LSD...Advice Needed
    By Toyo Truck in forum Tech and Conversions
    Last Post: 18-12-2007, 09:59 PM
  2. advice needed on suitable engine for ta22
    By TommyD in forum Tech and Conversions
    Last Post: 19-06-2006, 07:26 PM
  3. malpassi rrFPR - install advice needed
    Last Post: 07-02-2006, 06:43 AM
