Results 1 to 15 of 21
Thread: Carbon Canisters - Are they needed?!
    Junior Member Grease Monkey medwin46's Avatar
    Default Carbon Canisters - Are they needed?!
    Ok guys,
    Im trying to figure out whether or not i should include one in my car (3sgte AE86) as im nearing the final assembly.
    I've done a bit of research but nothing can clarify for me whether or not it is essential to run one.
    Im running a Microtech ECU etc so it will be tuned to suit the operating conditions of the car (sensors etc) and the fuel system is a surge tank setup with FPR, custom alloy tank and fuel rail.
    Any help greatly appreciated.
    Default Re: Carbon Canisters - Are they needed?!
    Hi mate,
    A carbon canister is there for emissions reasons, not to help your car run as such. vapours from your fuel tank pass into the canister and are then burnt by your motor i believe.
    In nsw you need on to get your car engineered, as it is part of the emission compliance.
    Stew
    They are sometimes also known as Charcoal Canisters - googling that might help too
    e.g. http://www.smogtips.com/charcoal.cfm
    It's more to do with complying with emissions standards than anything else. I can't say how effective they are in operation because I've never seen any proof. Some states require a minimum of a catalytic converter and a carbon canister.
    edit: Arrgh, beat me to it - for some reason I lost my first one
    Ballarat Vic
    As you are running a custom fuel tank and there are probably no prevision for the a canister line in the tank l wouldn't worry about it but because the car came out with it the rego people might want one on.
    Talk to an engineer about it.
    Rosco
    Thanks guys, the only reason i thought they may have been needed to run was that i read the fumes were fed to the inlet and burnt, thus making me think hhmm something going on here lol
    For the record, im in TAS lol inspection and engineering down here is sooooo breezy hehe be lucky if they pop the bonnet lol and when/if they do, they'll see the engineered plate and they're scared off by it. lol.
    As far as the engineer ticking it off, speaking to him all he's gotta do is run an eye over it and check it looks ok (which im sure he'll be impressed with!) and take it for a drive to check the brakes pull it up well enough (will be running 6psi boost only hehe) and do an emissions test, so i gotta get a cat..... lol
    cars in Oz have needed charcoal cannisters (part of the EVAP system) since before 1973 - they're nothing to do with the EFI system but a mechanism to catch and burn fuel vapours that don't return to liquid form in the fuel tank.
    TAS
    I'm not sure whether I need a cat either - car originally didn't have one...
    Depends on whether it is regarded as part of the car or as part of the engine. If you didn't have one and the car is stock then you don't need one. Otherwise I assume you would.
    rule of thumb: if the engine came with an O2 sensor, it came with a CAT ... ergo the engine should use a CAT regardless of the car that it's in or ECU.
    example: 1GGTE into 1981 RA40 - original engine ran leaded and no CAT, 1GGTE came from a donor vehicle but has O2 sensor and half-cut included a CAT, to get engineered, car now needs CAT.
    QED: doesn't matter if your car didn't have a CAT, it's what that engine used in it's original configuration.
    Forum Sponsor Conversion King
    Dec 2006
    Quote Originally Posted by medwin46
    for this reason you WILL need a charcoal canister.
    my recomendation is find one off a nissan (s13 s14 r32 r33) and use the original bracet and mount it under the car near your tank (wouldn't want to ruin the appearance of your engine bay), just need a 1/4" fitting in the top of the tank and run a vac line from the purge fitting on your TB
    linden
    linden
    Please elaborate Linden, will the emissions test be able to tell whether or not there is a canister fitted>!
    He'll probably take his noise meter with him when he takes it for a drive to do a noise test. I know John did that when he engineered my 1GGZE conversion in the Hilux.
    As far as the CAT is concerned, the chuckster is right, if the engine had a cat you then need a cat. I think here in NSW they go off what the engine was in, not your car. When I did the emissions test at Penrith, that's what the guy told me (which I knew anyway as John the engineer warned me so I took all the spec sheets downloaded off the net for the donor car).
    Not sure about the canister but I know I retained my Hilux unit when I did the conversion and just hooked it up. I'd hazard a guess and say your emissions test probably would be more of concern in other areas than whether or not you had a canister. I've heard of guys leaving it out up here and being OK. Is emissions testing free in Tas like it is up here?
    Peter
    The fuel tank should have a breather to allow for expansion & contraction of the fuel due to temperature change (I've never noticed but I assume all aftermarket "race" tanks/cells etc would have breathers?), and then the question is, what do you want to do with the fuel vapours that will make their way out of the tank.
    There would have to be a safety issue along side the emmissions issue there?
    A charcoal cannister solves both problems. Plus they're easy to get (really small ones not so easy) and can be stashed away virtually anywhere, as Linden said. I stashed mine under my front guard.
    For something that is so easy, free, safe & legal, why not.
    Hey Linden, do you put breathers in your tanks?
    Dec 2006
    Quote Originally Posted by BigWorm
    yep and run expansion tanks also incase it gets overfilled. tanks suck balls to make (or atleast complex ones do)
    if your getting an emissions test done it has nothing to do with noise.
    it is to check what vapours/fumes come out of your car and that means the WHOLE car not just the exhaust, thats why catch cans that aren't returned are illegal as well as many other things.
    ideally there should only be 2 places that release gasses from your vehicle 1 exhaust and 2 the charcoal canister.
    if you have a slight weep from a fitting or injector Oring they WILL fail you on the test.
    db test wont be to hard to pass as its easy to make a plate bolt in in place of an exhaust gasket.
    linden
    Write English! Grease Monkey GasedT18's Avatar
    If you have any regard for air quality and the environment and therefore a sensible and responsible person ;-) put one on. Hydrocarbons in the atmosphere contribute to smog and global warming.
    If you want to do it well route the evaporated gases through a BVSV and or VSV and to the engine - this ensures any evaporated HCs get burned when the car is running and when it is not the charcoal cannister deals with the gases - only of course if the activated charcoal is not 'saturated'; canisters need to be replaced at intervals to be functional.
    Here's one method http://members.optusnet.com.au/~gasedt18/evap.jpg
    Be nice.
    P.S. if anyone can help out with a 5M-E emissions diagram see my post in this forum http://www.toymods.net/forums/showthread.php?t=32147
    I managed to get one from Toyota today after being rebuffed from the same place (different person) last week but as usual it is a slightly different version from what is on the car but it is closer than anything I've got. I'm in the process of tracing around the system now. Tip - metallic silver felt tip pens can be used to label the vacuum lines.
    It's all probably pretty academic as in approx 15-20 years time there will be very little petrol around, probably a lot more ethanol but very expensive, and by that time the Chinese will have burned so much coal (others as well) that the future will be well and truly stuffed - lets not debate it here hey -> non car forum.
    David
    T-18 SE series 2 1982 3T-C dual fuel, now under resto
    3T-GTE rebuild with fancy gas bits under consideration
    AE71 CSX 1984 auto
    Parts Wanted ASAP - See Parts Wanted
  1. Lots of carbon coming from a 4AG
    By phrostbyte in forum Tech and Conversions
    Last Post: 08-10-2007, 08:50 AM
  2. working with carbon fibre
    Last Post: 21-06-2006, 09:37 PM
  3. Carbon canister purging tech info needed
    By nick.parker in forum Tech and Conversions
    Last Post: 30-03-2006, 07:03 PM
