if you dont mind having it idle high, you can just turn everything in the car on (lights, A/C, high beams, stereo on 11etc) and adjust the throttle stop screw until it idles ok, then add a couple of hundred rpm to that idle by adjusting the throttle stop a little more.
then you will never stall.........unfortunately if you have all the gear turned off, it will probably idle very high.
your other options are to get an inline idle control valve and split it into all 4 runners after the throttle, and put a little filter on the other end. this aint too good if u dont have spare vac ports on the runners though
) i coud make it adjustable(kinda like a throttle cable) and have the throttle return, pushing the button and acting as a trigger. i would only have to fab up a bracket. DAMNIT, i wish i had kept the icsv from the ST head it would have made it so much easier.
