Results 1 to 3 of 3
Thread: compression of 4agze map engine (in psi/bar)
    Junior Member Grease Monkey cartledge_uk's Avatar
    Nov 2007
    Newbury, UK
    Default compression of 4agze map engine (in psi/bar)
    I just compression tested the 4agze from the ae92 thats going in my adub.
    I know the compression is meant to be 8.9:1 but what is it in psi?
    I've read that the aw11 4agze should be 180psi, so surely the map should be higher?
    Anyway these are my results from warm engine
    Dry
    1 - 175psi
    2 - 182psi
    3 - 172psi
    4 - 180psi
    Wet-(tablespoon of oil down each bore)
    1 - 200psi
    2 - 230psi
    3 - 240psi
    4 - 240psi
    what are peoples opinions on those results? healthy or a rebuild needed?
    Default Re: compression of 4agze map engine (in psi/bar)
    looks like a very healthy engine to me... i got similar results, except mine was low on number 4.. (4 according to the distributor cap)
    If they all seem pretty close for the dry test and one is out on the wet test what does that mean ?
    Worn rings ?
    Worn valve seats ?
    Des
  1. does a 4agz ecu fit a 4agze engine?
    By ebb_4agze in forum Tech and Conversions
    Last Post: 21-11-2007, 03:51 PM
  2. MA70 --> JZA70 Conversion
  3. MAP computer on AFM engine with e-manage?
    By timgte in forum Tech and Conversions
    Last Post: 04-10-2006, 08:58 AM
  4. 4AG(Z)E Engine mounts
    By DiZ in forum Tech and Conversions
    Last Post: 05-04-2006, 10:00 PM
