Results 16 to 30 of 38
Thread: AE86 Defect Notice
    SignWriter Grease Monkey MZ20's Avatar
    Default Re: AE86 Defect Notice
    Well my 86 went over the pits today and the examination report was alot nicer than I expected:
    * indicator to cancel out
    * horn to operate (haven't connected the wire to my nardi)
    * windscreen washer hose needs connecting
    * repair ripped seat
    * seatbelt to retract
    * movement in steering (?? all the bushes etc are brand new ??)
    * diff leak needs rectifying (its a locker!!)
    * rectify running performance on fuel line (???)
    * fit immobiliser
    thats it.
    I'll have to see the examiner people tomorrow to clarify some stuff but overall not too bad I think.
    I guess now I can start to work out how to fit the SC12 I just got...
    Add to the defect list that your sig needs to be 5 lines
    Check the bushes inside your rack, they may be starting to crumble. Quite a cheap part, not too hard to install, big PITA is that you need to pull out the rack to do it though
    I would be asking for further clarification on the fuel line issue. Oh, and next time you take it to them, pull your rotor button out, and tell them thats your immobiliser
    err.. so dumb people don't accidentally fill with diesel?
    thats the stupid part,
    filling an unleaded car with diesel usually does no harm (besides draining tank)
    where as you fill a diesel with unleaded, and you cause all sorts of dramas!
    ie, a new diesel landrover is $20,000 to repair if you fill it with unleaded, (as everything has to be replaced due to contamination!)
    I got them to clarify the fuel line issue - they actually meant that the clutch wasn't smooth enough, which isn't surprising since its a drift clutch. I told them it is a "heavy duty clutch": and they said that to "just try and get it to run a bit smoother". Not sure what to do about that other than put in a "normal" clutch for him or something, or maybe a lighter flywheel???...
    If he said 'rectify running performance on fuel line' when he meant to say 'your clutch is too fully sik brew', then what kind of a mechanic is he?? I would be pissed that you were forced to let a retard touch your car!! What kind of clutch is it?? Pucker?? Put in a twin plate clutch, all the bite you will ever need, and none of the defect hassles!! Maybe a less aggressive clutch plate?? Allow it to slip a touch?? You can always change it back out.
    Oh, and your sig is still more than 5 lines.
    wa
    Quote Originally Posted by MZ20
    * fit immobiliser
    thats it.
    so umm, you went to the pits with a locker, no horn, windscreen washer not working and no immobiliser ? haha !
    My Corolla ! - 4AGTE
    KP61 - 4AGE
    Junior Member Grease Monkey Beserker99's Avatar
    Quote Originally Posted by Adsport
    Yes that also puzzled me.
    But mine passed the pits widout a working immobiliser. It's only mandatory if your gonna sell the car to have a working one.
    But having a working one is just good sense I guess hehe
    Also, I forgot to clamp down my battery as tight as it normally is. But I still passed
    Well this is a video-capture of said mechanic doing his job ....
    www.billzilla.org
    Toymods founding member #3
    wa
    in WA we have government centres where almost all inspections are carried out, no mechanics there..
    KP61 - 4AGE
    Yeah, got em here in ACT. Not even lawnmower mechanics, they do a short government course on how to inspect cars. The most serious deficieny in the course, is absolutely no people skills are taught.
    cheers Chuck.
    MS51Crown Coupe,
    quarantine is gay Backyard Mechanic rustyP's Avatar
    Do they, teach how to use, commas too?
    Just having a stab mate, n/o intended hahaha
    Yeah the reson I put it over the pits like that was to see what they said need ed work on, they give you 2 inspections to get everything right...
    also, LOL to the kittah mechanic - now theres 2 cats under there!
    Really?
    I thought that rule was dismissed O_o
    I guess not then...good to hear
    You get as many inspections as you need, you just have to pay for them!
