Results 16 to 25 of 25
Thread: 3S-GTE Distributor o-ring
    GT4 Freak, and Conversion King Squid's Avatar
    Default Re: 3S-GTE Distributor o-ring
    Quote Originally Posted by Matty P
    Thanks for the link.
    Wouldn't it be a speacialist job to replace the inner seal and bearing?
    Has anyone used one of these kits? What is the quality like?
    On that manual page linked above Installation of dist section 2a implies there is also the o-ring for the housing, is this the one you mean? doesn't sound too tricky!
    cease striving Conversion King RobST162's Avatar
    Quote Originally Posted by Joshstix
    If the leak is internal, which it sounds like from your descripion, you can buy a seal kit to replace the internal seal as well from http://www.kbox.ca/catalog/product_i...products_id=68.
    toyota also sell the various seals if you need 'em.
    I picked up the internal shaft seal from Castle Hill Toyota no worries - but stuffed if I know how to install it.
    Gone from 005 to XR5! Automotive Encyclopaedia Matty P's Avatar
    Quote Originally Posted by Squid
    Not much of a shaft on a 3S-GTE dizzy! see http://ugbox.net/~lance/GT4/Technica...istributor.pdf
    Also near impossible (but not completely) to replace with intercooler on
    That diagram doesn't show much - the shaft is actually a bit longer than it would appear.
    Since my engine is without intercooler, manifold, turbo, battery, dump pipe, alternator and radiator - getting access to it isn't really much of a problem
    Nothing looks tricky in the manual
    I'm not sure what other seals need to be replaced, but I think the bearing on the shaft would be rather difficult and any internal seals could be a problem because the dizzy housing is stamped with 'Do not open'!
    queensland
    I have replaced dozens of these internal seals at work. it takes about 1 hr if you have the right gear, and all goes well. you have to take off the drive dog, then press the shaft upwards, dismantling the guts out of the dissy as you go. you have to ignore the warning not to remove the insulation block and be prepared to spend ages realigning both magnetic pick-ups. good luck
    urgh... hmmm can we get this done somewhere?
    Quote Originally Posted by RobST162
    My thoughts exactly! Would a mechanic charge much to install the internal seals/bearing etc..?
    alright, well might take a rig up to an auto electrician I know and see what he quotes me
    Let us know how you go - I am still interested in getting someone to do this for me. I have already ordered the seal kit from kbox.
    Just to put this one to bed.....
    I bought the kit from kbox. It was about $AUD35 delivered within a few days.
    My mechanic is rebuilding the dizzy with the new seals etc.. Apparently there is a special tool you require, but your mechanic should be able to do it.
    Hopefully I won't have a leak after this
  1. 5S FE to 3S GE
    By adam golder in forum Tech and Conversions
    Last Post: 05-10-2007, 09:47 PM
  2. oils an't oils what to use in a 3s gte?????
    By sirbabblealot in forum Tech and Conversions
    Last Post: 14-02-2006, 09:26 PM
  3. 3S BEAMS & 6 speed Altezza gear box into KE30 chassie
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 03-01-2006, 10:59 PM
