Blown 100A fuse was the cause
i looked at it but didnt click... one of those mornings unfortunately
Hey fellas
I've picked up a stacked jzx83 a while ago and transferred it all over to mine and have a handful of problems
i put it all together and it started alright then died after a bit, had to use the diag port to hardwire the fuel pump to keep it running which is fine i know what the problem is there
saturday night i started it up to show guests what it sounded like without an exhaust at allgave it a rev and it would hit a limiter at about 2500rpm. dont remember much else about that night, nothing sinister i think. but i tried starting it sunday and nothing happened. battery is still alright, as alarm works and headlights, interior lights, the open door light on the dash works but nothing else on the dash lights up. i turn the key to ignition and nothing happens
any idea what it might be? i checked fuses and i blew 'dome', so thats replaced but all the other fuses are fine
edit it seems it's not going into the whole ignition mode at all, i cant use power windows either![]()
If its still hitting the "limiter" at about 2500rpm. I had that problem with mine, it was the TPS not getting 12v power.
TPS is 5V not 12V....!Originally Posted by gz10 soarer
Ok Thats wierd cos the damn auto elec hooked it up with 12v. Then again it wouldnt be the first "professional" thats clueless.
Cheers for the correction.![]()
