Results 16 to 22 of 22
Thread: 3tgte gurus please help me.
    Default Re: 3tgte gurus please help me.
    for future reference, without the ball it idles at a nice 3500-4000rpm
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    If it idles that high the valve must be stuck open or leaking somewhere, or not connected correctly. All it does is control airflow that is bypassing the throttle plate. Effectively the same result as holding the throttle open a bit more but heat and time controlled. I guess a predecessor to the current pulse width modulated idle valves used on motors now
    i dont have the valve on there, its just a hose from the thorttle body to the plennum
    thats the problem then!
    Jul 2007
    maybe if you bought a new car and didn't have that old bomb you'd be right
    hmmmm . . . . . and who are you to say that
    Block it off. Mines blocked off and engine runs fine, with the standard system it may be better in the cold but you live in QLD right.
    If you put a tube between the two it is the same as having your throttle half open.
  1. fun times with 3tgte - parts/advice needed
    By ta22-3tgte in forum Tech and Conversions
    Last Post: 07-08-2007, 08:33 AM
  2. For you 3TGTE gurus
    By chesmari in forum Tech and Conversions
    Last Post: 27-07-2007, 12:01 AM
  3. 3tgte oil pressure
    By jeffro in forum Tech and Conversions
    Last Post: 15-07-2006, 07:03 PM
  4. 3tgte ECU and turbo
    Last Post: 27-06-2006, 05:16 PM
