Page 6 of 6 FirstFirst ... 456
Results 76 to 83 of 83
Thread: 2tgeu install help
  1. #76
    Junior Member Backyard Mechanic sleeektoy's Avatar
    Jan 2007
    Auckland
    Default Re: 2tgeu install help
    Congratz - we all get there in the end - albeit 3 weeks later lol
    _____________________________________________
    TA27 GT - How rare can you get!!!
    RA28 GTV daily driver
  2. #77
    Neverland 1 2tgeu nil.
    Wheelie.
  3. #78
    Quote Originally Posted by wheel rim
    Wheelie.
    --Corrected--
    Neverland 1 2TGEU 346,327,865
  4. #79
    Junior Member Grease Monkey Neverland's Avatar
    Nov 2007
    hahah too true
  5. #80
    Phantom fixes like that are a little worrying as the problem may resurface later at usually the most inapproriate time.
    If nothing more than removing tape "fixed" the problem then it would point to a bad connection or break in the wiring somewhere possibly.
    Give the wiring a move and jiggle at various locations while the car is running and see if it stalls or stutters at all whille doing so. If it does then try to pin point the problem. If it seems all sweet then tape it up and drive in fear of an imminent break down
    Good luck with it.
  6. #81
    Quote Originally Posted by Neverland
    Wish me luck!!!!
    Good luck neverland
  7. #82
    Nov 2007
    Well took her for a good test drive. with a dodgy exhaust she still pulled hard from 4-5.5 grand. Much more poke than the old 2t with weber extractors and lumpy cam. I also think she's a tad lighter on the steering too .
    Over all the temp range stayed around 70 deg. on the gauge, don't know how acurate it really is . the theromstat seemed t open, the radiator was warm down below, so overall I'm pretty stoked.
    now next month I'll get a proper exhaust when I have spare $$ to play with.
    What size do you guys recommend?
    I was thinking 2 1/4 with hotdog in the middle and rear sports box into a 3 inch dump.
    also after a few drives should I recheck the head bolts? or should they be right?
    Thanks again guys for all the input you all saved my sanity from being beaten to a pulp
  8. #83
    Nov 2007
    ps. sorry forgot to add. dizzy is set at 16deg btdc@1000rpm. Is that right aswell?
  1. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
  2. Vacuum Diagram for 2tgeu?
    By 74sLeeka in forum Tech and Conversions
    Last Post: 29-10-2006, 04:12 PM
  3. 2TGEU and 3TGTEU Pistons/Crank Question
    By GeneSPIDA in forum Tech and Conversions
    Last Post: 11-05-2006, 09:30 PM
