Results 1 to 6 of 6
Thread: Can I run fuel pumps mounted vertically?
    Bogan Hunter Grease Monkey
    Default Can I run fuel pumps mounted vertically?
    I have a Bosch 044 high pressure pump, and a low pressure lift pump that I want to mount vertically instead of horizontally.
    Any problem with doing this?
    Is the reliablility of the pumps comprimised at all?
    S.A
    Default Re: Can I run fuel pumps mounted vertically?
    No prob at all...
    As long as the big pumps have their fuel supply gravity feed youl be sweet.
    The 044 pumps (most efi pumps ) cant draw fuel properly or at all and must be fed by gravity
    isnt that what the low pressure lift pump is for 30psi?
    S.A
    Quote Originally Posted by love ke70
    Yep..
    BUT i wasnt sure if he was going / meaning to mount the 044 pump verticaly above the surge tank and therfore having issues
    You can actualy do it....Mount the pump higher than its supply but........ as a general rule you cant -- because it doesnt always work
    FWIW I run a vl turbo EFI pump as a lift pump and have it mounted verticaly slightly above the it supply at the bottom of the tank..
    Awesome cheers for that.
    The way I've got things, everything will be under the tank, so the surge tank and pumps shouldn't de-prime..
    Cheers again!
    Forum Sponsor Conversion King
    just made sure the inlet is at the bottom as the bosch pumps will cavitate hard if air gets inside them. the inlet is the M18x1.5 fitting on the back of the pump.
    your actually better off mounting 044s on an angle or vertically as it decreases how noisey the pump is (still havn't figured out why)
    linden
  1. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 11:12 PM
  2. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 02:05 PM
  3. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
