Results 1 to 7 of 7
Thread: Mx83 speedo sender
    victoria
    Default Mx83 speedo sender
    Howdy happy people
    just wondering if anyone can confirm that the MX83 speedo sender operates on 5V and not 12v, did a search but couldnt find anything.
    Just hoping that i dont have to go grime surfing again and swap it over.
    thanks
    Default Re: Mx83 speedo sender
    MZ12 Soarer which looks the same as MX83 grande is 12V...
    Then again I'm pretty sure that the dash has a diode and its own internal pull up so it doesn't really matter...
    victoria
    edit- its in a ra23 w58/1g running off a home made loom and a speeco spedo
    I wired it up and couldnt get a pulse, so had a chat to my mate with a soarer and apparantly they run all 5v in the dash,so forth, which got me a bit worried.....
    Have you tried removing it and turning it over by hand slowly to check you get a pulse out?
    That would be where I'd start...
    Operates on 12 volts
    Jealousy is a curse
    victoria
    ill pull it out tomorrow and test it.
    One pin is earth , one is +12v , the other is output. Make sure you have it earthed properly.
    Jealousy is a curse
