Page 7 of 7 FirstFirst ... 567
Results 91 to 94 of 94
Thread: 1UZ: advancing the intake cam does 'what' to the exhaust cam... ??
  1. #91
    Canada
    Default Re: 1UZ: advancing the intake cam does 'what' to the exhaust cam... ??
    Quote Originally Posted by MWP
    The fact they use the word "duty" in that text means it does use PWM.
    Thanks for the diagram.
    I tend to be kind of retentive. I don't like to make direct statements of fact unless I have firsthand knowledge or experience.
    What I would dearly love to watch is some duty data, and relate it to the cam movement that it creates.
    Imagining or picturing the relationships is fine, but watching them using data is one step better.
  2. #92
    Penrith BC
    when i get the sm4 tuned for the VVTi ill update with the actual numbers if you like - will be a while though
    ../delete/ban
    tech moderator
  3. #93
    Quote Originally Posted by 3sgte
    "duty data" would be a percentage which then translates into a PWM signal.
    From the simplicity of the valve design, the PWM duty compared to valve position and hence cam position would be linear.
    Ie, 100% = full advance, 0% = full retard, 50% = center.
    It would be quite easy to work with.
    BTW, im only thinking about all this as i want to design & build my own engine ECU at one point in the future.
    Im sure the higher end aftermarket ECUs make VVTi control pretty simple.
  4. #94
    Quote Originally Posted by ed_jza80
    does anyone know of a 3uz engine manual online??
    ed
    http://techdoc.lexus-europe.com/xcvr...nts/index.html
  1. T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
    Last Post: 29-02-2016, 11:30 AM
  2. 4AGZE Intercooler and exhaust suggestions?
    By DavisJD in forum Tech and Conversions
    Last Post: 07-02-2006, 05:20 PM
  3. Underbonet & Intake temps
    By Alchemist in forum Tech and Conversions
    Last Post: 09-12-2005, 03:56 PM
