Results 1 to 10 of 10
Thread: Query? 2TG Petrol to 2TGTDI Diesel Conversion?
    Not known unless ur blown Backyard Mechanic
    May 2007
    Default Query? 2TG Petrol to 2TGTDI Diesel Conversion?
    Hmm as of last night talking to an engineer, i'm casting doubts over a high comp. LPG 1.8L 2TG.
    I'm curious is there a way to change the 1.8L 2TG into a turbo intercooled diesel 2TGTDI?
    The 3T cast iron block would hold the compression, plenty of meat!
    88261 heads I'm sure also would be plenty strong enough for the job..
    Manufacture parts to suit the very high compression, bead blast everything so it can disperse heat well and not give either the block or head to much stress..
    Now im curious could it be done?
    Default Re: Query? 2TG Petrol to 2TGTDI Diesel Conversion?
    Can it be done? Sure, why not. Should it be done? Um, no. Believe it or not you can actually buy engines that already run on diesel.
    May 2007
    Yeah but you can't buy a 2TGTDI Pointless totally, but +10 uniqueness everything the muztang has to be about
    It would really not be feasible. How would you mount the injectors the only way would be through the spark plug holes and on a 2tg that woud be hard. I've never seen a screw in injector. Then there would be the problem of mounting the injector pump. Where would you drive it off remember that the pump must turn in time with the engine so it would inject the fuel at the correct time of the compression cycle.
    Piston design would need to match the style of injection so a good mix of fuel and air other wise it would not run very well. Stopping the head from lifting off the block would be a big drama remember diesel needs about 16:1 comp to get any sort of a bang then your going to put boost on that again. And the list would go on with problem areas.
    The totoal cost of this project would be very scary
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    May 2007
    HAHA ok well in the words of mythbusters, BUSTED.. guess thats not a totally feasible idea oh well... Very much thanks for the imput
    Junior Member Domestic Engineer Hurricane's Avatar
    i guess you could run a comon rail setup useing an ecu but with all the time and money it would need to change it to diesel, it would really be a waste of time? nice thought thow
    And if you have thr money to do such a thing, ill take some off your hands
    cheers, dan
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    Time to spank the Grease Monkey
    To indulge this idea, a 3T-GTEU head would give a spare hole for DI - it's what Alfa Romeo did going from Twin Spark heads to DI, just used the same engine, same head, half the spark plugs! It would then be interesting to see if someone would go petrol DI on a 3T-GTEU - Any takers?
    AE92 Lueno GT-Apex (zenki Trueno with a Levin front end) - BT 20V & LSD
    KE30 Tudor - 2T-GEU, T50, T292
    Aug 2013
    FNQ, QLD
    For the money you'd spend on converting, maybe find a 1KZTE front cut from a lux or hiace. Factory TDI with alot more proven reliability.
    "Cressbox" 1987 MX73R -Hardparked
    "Tractorpimp" 1985 MX73R-under construction
    D21 Navara- sent into the lungs of hell (Rust in Pieces ya farkin)
    Jan 2007
    queensland
    delete post
    Jul 2007
    smokinsquirrel - stop updating old ass threads for fucks sake
  1. MZ20 - 7MGTE To 1JZGTE Conversion Pics (56K Warning)
    By Danners in forum Engine & Driveline Conversions
    Last Post: 07-05-2008, 10:02 AM
  2. MA70 --> JZA70 Conversion
  3. 20v BT Conversion in AW11 - DPI info / query...
    By kassma in forum Tech and Conversions
    Last Post: 31-07-2007, 10:10 PM
  4. mz20 conversion query
    By spoolintanabe in forum Tech and Conversions
    Last Post: 13-01-2007, 07:51 PM
  5. mate put petrol in a diesel... what now?
    By lojik in forum Tech and Conversions
    Last Post: 23-01-2006, 02:11 PM
