Results 1 to 10 of 10
Thread: cam pulley specs needed from various toyotas
    User Conversion King
    NWA
    Default cam pulley specs needed from various toyotas
    im hoping to drive the M90 supercharger with toothed cam pulleys so im trying to find suitable pulleys to aquire the ratio i want.
    what would be awesome is if people could count the teeth on any cam and/or crank pulleys they having laying around.
    more then likely many of the belts will have the same teeth pattern and pitch but i can check that out once i know what pulleys have how many teeth
    im aiming for something around 1.5:1
    i have a set of 7m cam gears but i only have the sizes 24(crank), 46(oil pump shaft) and 48(cams). the best ratio i can get from this is just under 2:1
    ive counted a couple pics from google and it looks like the 3sgte has 36 and the 4age has 38???
    if i could get some various cam specs then i can take a belt with me to the wreckers and find something thats going to work.
    hello
    Default Re: cam pulley specs needed from various toyotas
    4AG has 36.,. 10deg per tooth (and so must have 18 tooth crank)
    the 1G is the same? as 4AG?
    NWA
    i no longer own a 1G to check but could be the same.
    36 tooth would be awesome as 36/24 = 1.5:1
    can you measure the overall diameter off the pulley as i should be able to determine a pitch ratio that way.....and check it against mine. hopefully the belts are compatable
    hello
    xJZ-GTE Cams pulleys are 48 teeth,
    Crank would have to be 24...
    4age: http://www.toymods.net/forums/showthread.php?t=23350
    Traditionalist Domestic Engineer parrot's Avatar
    I get 101mm with my verniers, inner tooth to inner tooth, and 36 teeth
    And 108mm at top surface of tooth.
    Sorry that's 4AGE bigport
    NWA
    any chance you could measure the tooth pitch of the belt?
    best way is to measure 10 teeth from the start of tooth 1 to the start off tooth 11
    the 7m cam belt measures 8mm this way
    hello
    Am at work now with the pulley in front of me. An inexact measurement with a ruler per your instruction gives approximately 94mm. No verniers in hospitals.
    I am happy to post you one to play with if you like. Then you can just post it back again later.
    If yes, send me a PM
    Penrith BC
    Quote Originally Posted by parrot
    Am at work now with the pulley in front of me. No verniers in hospitals.
    apparently theres cam pulleys though! lol!
    ../delete/ban
    tech moderator
    Of course, we keep one as a spare for the machine that goes "PING!"
    1g is 46 teeth, same as a 3s.
    109.5mm dia between teeth and 115.5mm on the teeth.
    hope this helps,
    cheers, andrew
  1. sc series blower specs needed
    By DryftKult in forum Tech and Conversions
    Last Post: 30-06-2007, 06:11 PM
  2. 4agze piston specs needed
    By rotated7 in forum Tech and Conversions
    Last Post: 27-06-2007, 07:27 AM
  3. 4age tensioner pulley HELP NEEDED
    By sxtool in forum Tech and Conversions
    Last Post: 31-03-2007, 07:14 PM
  4. 4AGZE - EA Falcon Pulley Mod
    By TooF in forum Tech and Conversions
    Last Post: 15-05-2006, 12:23 PM
