Results 1 to 6 of 6
Thread: welding nuts to chassis
    Default welding nuts to chassis
    Had a problem today where one of the captive nuts that the lower control arm bolts onto has been stripped out and also moved away from it's holding.
    So, a new nut, or a stud will need to be welded in it's place.
    Who is best to go to for this sort of work? It's a relatively simple job except for accessing the cavity where the nut is held... and being that it bolts a LCA to the chassis in this point I'd rather get someone do it who knows what they're doing won't weaken the chassis at all
    Any help or advice greatly appreciated!
    I am the sun
    Junior Member Backyard Mechanic M.J.H's Avatar
    Default Re: welding nuts to chassis
    Geez you have had some bad luck with the cars.
    Is the other side of the chassis easy to get to or not?
    My first thought was to put a longer bolt through with a crush tube and a nut on the other side of the rail to hold it all but maybe a job best left to a decent panel beater/repair shop.
    It doesn't look to be accessible at all
    At least it wasn't my car this time around!
    I wouldn't have even thought of a panel beater, they might be the best people for this one
    I am the sun
    sir Grease Monkey
    tasmania
    any decent boilermaker would do it for a 6pak of turks and they will make it look that easy you won,t want to pay them .just make sure the area in nicely cleaned and all suspension bits are out of the way. cheers bigwad
    Is the nut part of the x member? If it is then remove that if you cant get to it.
    Nope the nut is in the chassis itself
    Cheers big wad!
    I am the sun
  1. mig welding car panels
    By styler in forum Tech and Conversions
    Last Post: 11-08-2009, 04:45 PM
  2. TIG Welding supplies!
    Last Post: 12-10-2007, 04:29 PM
  3. Aluminium Wheel Nuts - Use Care - Lost a wheel at 60km/hr today - stripped bolts PICS
    Last Post: 28-02-2007, 02:46 PM
  4. Gland nuts
    Last Post: 03-02-2007, 08:16 AM
  5. Old RWD Wheel Studs / Nuts Size
    By Screamn_Sleeka in forum Tech and Conversions
    Last Post: 21-06-2006, 05:51 PM
