Results 1 to 15 of 20
Thread: 4AGE carbed dizzy - EPC request
    Victoria, Mt Macedon
    Default 4AGE carbed dizzy - EPC request
    Over the weekend I had a quick look at a carbed 4AGE. It ran what looked to be a factory dizzy that had mechanical and vacuum advance and electronic points. And seemed to bolt to the head perfectly.
    The only identtifying mark I could find was a part number on the dizzy cap. It was 029120-0570. Is there anyone who could cross reference this in the EPC? I'm very curious if it was a factory dizzy, and if so then out of what.
    Thanks
    Hen
    Default Re: 4AGE carbed dizzy - EPC request
    That number doesn't work in EPC but did the dizzy look like this?
    No, not like that. It didn't have an inbuilt coil. It just looked like a normal round dizzy cap. It could well have been non-Toyota I suppose.
    Thanks for looking it up though. Is that dizzy you've shown an option for this setup?
    Hen
    Traditionalist Domestic Engineer parrot's Avatar
    If you google the part number, it comes up as
    Distributor cap daihatsu 029120-0570
    That should point you in the general direction.
    And now I'm trying to work out why I didn't do that in the first place...
    Thanks Parrot.
    Love that google.
    And it would be a four cylinder so perhaps easier to narrow down.
    New Zealand
    thats a nippon denso part number
    cant use them with toyota
    there are some toyota dizzys that can be modded to work with the 4age
    but i cant recall accurately which ones they are
    please, no more PMs!
    Got your ute back Nath Grease Monkey 75Ta22LT's Avatar
    Use the standard dizzy,
    Buy the following MSD ignition control parts.
    PN 8981 - programmable timing control $475 (Superplus parts - aus.)
    - Fully programmable ignition curve (initial timing, advance point, slope of advance)
    - High speed retard function (for nitrous etc) - adjustable via plug in modules.
    PN 6420 - 6AL control unit $395 (ebay - america)
    - Required to run the timing control above.
    - Soft touch rev limit - adjustable via plug in modules.
    - Increased spark voltage and capacity
    - Triple spark under 3000rpm, for 20deg. duration
    Both CARB approved.
    allows you to completely remove the 4age ECU system.
    Double the price of a good dizzy setup... but no screwing around, just hook it all up and give it a run on the dyno for fine tuning.
    Hoppers Crossing
    blardy eck
    if you want an old style dizzy, go to scorcher ignition in nunawading, tell them what advance curve you want and you're done.
    last quote i had was $450 all told.
    Junior Member Backyard Mechanic Dimitri's Avatar
    neither option really stacks up price wise i dont think.
    japs often used a prticular modified 4k (7k?) one. the cap looks the same(as stock rwd 4age) but they use some type of adaptor plate between the dizzy and head.
    www.delta-digital.com.au (i think) is an ozzy company making an decent (looking) ignition only ecu if that helps anyone. its what i came up with as the best solution when considering going down that route.
    anyway this is all o.t, but im definately going to check back here to see what you come up with.
    Update*
    Ran the car with just the 6AL hooked up, the timing computer is in place but no timing modifications are set.
    With static 20 degrees advance, the car idles suprisingly well, triple spark helps A LOT.
    Yet to run it over the dyno, but looking at very good power once the timing is set and the curve is worked out.
    Gents, I fully understand there are other options to do it better electronically, however this engine I want to build with carbs and with a dizzy. I have never worked with them before and want to learn.
    The dizzy I saw looked like a great fit, had vac and mechanical advance and electronic points. Basically exactly what I am wanting. I'm also playing with a 3k dizzy but that needs an adaptor that I CBFed making right now.
    So I was just trying to chase up an ID on that Daihatsu dizzy. In any case, the Daihatsu forums aren't much help either.
    Hen
    AB
    I have been thinking about this issue as it seems to be comming up more and more often. I had a look at a 3A dizzy i have and i would speculate you could get it to work. You would need to replace the gear with a 4A one but the dizzy does have mechanical advance and there is no ignitor built in. This is just a thought as I need my dizzy for my 3A and am unwilling to start modifying it. Anyone outhere who knows if this can be confirmed or denied? Not wanting to send anyone astray, but it does look like it should work.....
    Quote Originally Posted by merc-blue
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
    Key word: *CBFed*
    You'll put in a LOT of work to sort out the drive gears alone if you can't find something that suits perfectly without modifications. Performance wise, mechanical (or vacuum) advance cannot compete with an electronically programmable curve.
    I reaserched the crap out of this, the moment I found a solution that did not involve distributor modifications, I jumped at it. The additional features of these electronics control units makes them well worth the purchase.
    I'm simply trying to stress the performance value's here...
    Sure the dizzy will give you advance, but won't be quite as versatile as an electronic control unit.
    Junior Member Backyard Mechanic TC1600's Avatar
    Feb 2007
    Why not try a Daihatsu dealer, or a workshop that deals with them regularly? Mind you that might be hard as I don't believe they are sold in Aus any more?
    My choice would be a Megajolt setup, cheap and looks like it would be reasonably easy to get at least a base setup sorted. Would be ideal if you can use the pulse wheel from the original 4AG distributor.
  1. 4AGE 100kW Dizzy Oil Leak Guide
    By Talasas in forum Tech and Conversions
    Last Post: 05-11-2014, 08:00 PM
  2. How to avoid dizzy on 4age?
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 18-01-2007, 07:42 AM
