Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: Need a SC12 setup victim to test a 95mm clutched pulley
    Jan 2007
    Default Need a SC12 setup victim to test a 95mm clutched pulley
    i have made a 95mm sc12 clutched pulley and i need someone with a sc12 setup runing a 5pk belt or lower to try the pulley for me.
    the guy needs to be close to tweed heads postcode 2485. goldcoast
    anytakers. if alls well i will produce them.
    thanks joe
    msn
    [email protected]
    Junior Member Automotive Encyclopaedia wasfishing's Avatar
    Aug 2006
    NT
    Default Re: Need a SC12 setup victim to test a 95mm clutched pulley
    i would try it for you but im in NT
    MISTR2 - 1988 AW11 MR2 - 4agze soon to be turbo
    Daily - 1994 -HR33 Skyline Gtst - The white whale
    Jan 2007
    Arrow Re: Need a SC12 setup victim to test a 95mm clutched pulley
    any guys closer thanks
    Jan 2007
    to the top
    Victoria, Mt Macedon
    I'll offer, though Melbourne still isn't too close.
    Hen
    Chiba
    I'm in Brisbane with a 4AGZE AE101, but I don't think that's in NSW (last time I checked)....
    Def. interested in the pulley though. Do you know how much boost it will produce?
    Jan 2007
    on a 4agze stock engine it will produce 15 to 16psi.
    you just have to do a airbypass mod and your all go.
    this is good for stock setups as cars with larger crank pulleys will run too much boost.
    cheers joe
    Chiba
    Sounds awesome. What sort of cost for the completed item?
    I can test for you if you can get it to Brisbane. I have already completed the bypass mod.
    Jan 2007
    they will retail for $200 to $300 with instructions.
    i will get your details when i get home and come up and do the mod. in a few weeks.
    Chiba
    You have PM.
    Quote Originally Posted by racer
    cheers joe
    Giday Joe, what do you mean cars with larger crank pulleys will run too much boost? It wont run too much boost if the crank pulley isnt too big
    What do you define as too much boost? 15-16psi is certainly getting up there for the sc12.
    As this is in tech and conversions it might be an idea to include some tech info on the product. Or maybe get the thread moved to general car talk. Pro's and Con's of using a larger crank pulley v's a smaller sc pulley as way of increasing sc speed have been discussed in various sections.
    Jan 2007
    if you increase the size of the crank pulley you increase the speed of the supercharger rpm. aswell if you decrease the size of the supercharger pulley you increase the supercharger rpm.
    if you do both it increases drematicaly. and it makes too much boost.
    the 95mm clutch pulley has the same benifits of the orginal pulley.
    running a larger crank pulley increases wear on other components attached to the belt system. so they wearout much quicker than normal.
    joe
    Jan 2007
    on a 4agze engine with 120mm crank pulley the figures will be similar.
    with 95mm pulley
    supercharger rpm 8800 at 7000rpm engine speed.
    225hp/168kw at 7000rpm
    at 15psi boost
    standard specs
    supercharger rpm 7300 at 7000rpm engine speed
    185hp/138kw at 7000rpm
    at 10psi boost
    or
    supercharger rpm 6700 at 7000rpm engine speed
    171hp/127kw at 7000rpm
    at 8psi boost
    Junior Member Grease Monkey kojab's Avatar
    Nov 2007
    N.S.W.
    Would the SC12 pulley you are making fit a SC14 Super Charger?
    Jan 2007
    no but i have already made one for the sc14 blower but it is 103mm. which is the smallest it can be but still holding the clutch mecanism.
    is on ebay under
    103mm supercharger pulley
  1. 4AGZE - EA Falcon Pulley Mod
    By TooF in forum Tech and Conversions
    Last Post: 15-05-2006, 12:23 PM
