Page 10 of 85 FirstFirst ... 891011122060 ... LastLast
Results 136 to 150 of 1266
Thread: 3T GTE Tech
  1. #136
    Default Re: 3T GTE Tech
    get the Wolf on and tuned - afaik there is not a great deal of tuning that may be done with the factory ECU. You are not going to see great gains going to FMIC without a corresponding tune.
  2. #137
    Junior Member Grease Monkey rke_011's Avatar
    sa
    cheers YelloRolla for your help, seems like your the man when it comes to 3t's
    another quick question, my 3t i believe is the old style without factory oil cooler.. would it benifit with a oil cooler fitted... if so any suggestions on ones that would "bolt on" any factory cheaper ones??
    thanks again..
    Mat
    1970 - Ke11 - 12a j port -for sale (sold)
    1969 - Ke10 - 4age (sold) - .... And I just bought it back again less a 4age now to be turbo 5K
    1969 - Ke10 - 4age pocket rocket
    1967 - ke10 - Im the second owner... WANTED FREE 4K TO DONATE TO A GOOD CAUSE.
  3. #138
    You may benefit from going to an oil cooler, BUT, I have found that using a sump of increased capacity and greater surface area keeps the oil cool enough for a hard driven streeter, but would probably not suffice for a track car that is expected to do 40 mins of FLAT OUT driving.
    The engines that were fitted with an oil cooler use a different sandwich plate under the oil filter with a thermo wax (or whatever you call it) which opens and lets oil flow through the cooler. There is a banjo fitting at the thermostat housing for the return path.
  4. #139
    Nov 2007
    MOTOR IMPROVEMENTS SUMP/OIL LAYOUT
  5. #140
    The modification of a factory Sump for increased volume and ideally baffeling is deffinatly not a bad idea.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  6. #141
    New Zealand
    Any aftermarket options around? The 3T is pretty popular in the US so presume something is available?
    Callum
  7. #142
    Moroso make a couple of alloy sumps for them, Not sure how well it fits in a Celica but the measurements and dimensions for them are online. They are not a cheap item tho for the good ones. and there entry level Sump is no where near as good as the JMR jobbie on mine and with the current exchange rate they cost allot more.
  8. #143
    Texas,USA
    How is this JMR I see you guys talking about? Do they have a web site or a way I can get a hold of them?
    ae-86 (levin) footwork
    TE-71 w/1uzfe
    Autronics SM4
  9. #144
    JMR = Yellorolla
    Toyota Car Club (Qld)
  10. #145
    Yellorolla = Jason Myers
    JMR = Jason Myers Racing
    Conveniently active on a Toymods forum near you
  11. #146
    sa
    ok im thinking about putting in the old wolf 2d to control fuel... is it worth getting a fuel reg? if so what type? specs and info would help as i dont know much about fuel systems
    thanks again
  12. #147
    As long as it is working properly there is no good reason to change the factory fuel pressure reg, In fact aftermarket adjustable furl pressure regs and a defectable item (By the EPA) so why invite the problem.
  13. #148
    A 2D fuel controller on a turbo charged car is a really poor idea. The computer has NFI about engine load so if it is tuned to be safe at X revs and full boost it will be retardedly rich at the same revs without the boost, that's the best case. Worst case scenario it's tuned nicely on the dyno then you drive it up a big arse hill that gets the engine making boost at revs it didn't on the dyno, it goes lean because of hte extra air being ingested still with the same amount of fuel for those revs and it ends with a busted motor.
    "Decent" computers are so cheap these days there is no reason you would use such a rubbish old setup these days. A better computer will give far better results and also is less likely to cost an engine rebuild or double your fuel consumption.
  14. #149
    Perth, WA
    this is one hell of a kind 3T-C
    any one have specs and where this monster runs?
  15. #150
    sa
    Quote Originally Posted by Joshstix
    Understandable if you have thousands to spend on a car, but when your on a budget you have to use what you have..
    the 2d ran my brothers 13bt for years fine, why would if be any different on the 3t? also i dont know what this means but this is written about the wolf 2d
    "Don't be fooled by the "2D tag, this unit has full 3D mapping, and can use the fuel map from a 3D using all 128 points."
  1. 3T Versus 3T GTE conrods
    Last Post: 17-04-2011, 09:39 PM
    Last Post: 15-04-2008, 06:13 PM
    Last Post: 01-06-2007, 01:59 PM
  4. html in the tech section
    Last Post: 28-12-2005, 11:49 PM
