Page 14 of 85 FirstFirst ... 412131415162464 ... LastLast
Results 196 to 210 of 1266
Thread: 3T GTE Tech
  1. #196
    Default Re: 3T GTE Tech
    gasket is definitely the same - why wouldn't you buy a new thermostat?
  2. #197
    I will be buying new, wasnt sure if you could get 3tgte stuff still.
    RA23 - Twincharged
    JZZ20 - Daily
  3. #198
    They're the same, only the temperature at which they open may be different. If you buy aftermarket, you can try different opening temps to help control your coolant temps.
  4. #199
    Tasmania
    im struggling to find a head gasket.
    toyota dont have any in stock, they have a full gasket kit, but only one, and wont septerate.
    1973 TA22
  5. #200
    I can get them - I probably have one in stock that I can send you. PM for more details.
  6. #201
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    arent the 2tg and 3tg head gaskets the same? i think i read that somewhere BUT am not sure so dont take that as gospel
    they're the same.
  8. #203
    Texas,USA
    I went the copper + oring method trying to get set up to run E85.
    YelloRolla just curious what head bolt torque setting do you use with the Mitsu. studs?
    Also what total timing are you using?
    Just looking for some comparison feedback.
    ae-86 (levin) footwork
    TE-71 w/1uzfe
    Autronics SM4
  9. #204
    ARP says 80ft/lbs as long as it is used in conjunction with their moly lubricant. Each stud needs to be torqued down 3 times.
    To be perfectly frank, I have not used that stud in one of these engines yet. I have used lots of studs in lots of engines, just not the Mitsu stud in the 3T GTE head (or 2T G for that matter) as I have used my own studs previously.
  10. #205
    Texas,USA
    I have them set a 70ft/lbs.
    What about timing? I have been running 19 btdc with 93 octane. Under boost of coarse
    TE-71 w/1uzfe
    Autronics SM4
  11. #206
    There are too many factors involved to make any statements about ignition timing - exhaust manifold, turbo choice, intake manifold etc can all make a HUGE difference to how the combustion process will behave. One of the factors affecting how much timing an engine needs (that is "needs" rather than what it will "tolerate") is exhaust gas dilution of the intake charge. Small turbine housings and shite exhaust manifold will have an immediate effect, the engine will tolerate more timing due to reduced combustion temps slowing the burn rate.
  12. #207
    Texas,USA
    Yes I realize all that I just wanted a general comparison. I have not been able to talk to someone that has done some of the things I have done with this motor. I have some ideas on what I am going to due after I get this thing going again. I have had some problems in the past with head gaskets and ignorance on my part. (not enough water) That is why I said screw it and did the oring copper head gasket along with lower compression ratio. (went from 8.5:1 to 8.0:1) I know the potential is there in the engine I need to increase my tuning skills. I have read some good articles on reading plugs. I have in the past just relied on a wideband and guessed on the timing based on what I know about other motors. That is how I came up with 19*. I have talked to some of the 3tc guys and they thought that might be to little timing. Anyway I will get this thing on the track and look at the plugs along with wideband results.
    TE-71 w/1uzfe
    Autronics SM4
  13. #208
    I made the best power with 18 degrees at full load (from memory).
  14. #209
    nuts Grease Monkey
    auckland
    Quote Originally Posted by YelloRolla View Post
    The CT20B has a bit better response with the twin entry housing, I had the 7M GTE exhaust housing on mine - in each case that I have been involved in/driven were the steel turbines and not ceramic, a ceramic turbo would be that much the better.
    I hope that your planning to run 20psi.
    hey, are you saying the twin entry housing bolted to a std 3tgte single entry exhaust manif works better than the single entry ct26 housing even though the manifold itself is not a split pulse design??
    -Mark
    E2 + E7 fan
  15. #210
    No, I am not saying that at all - sorry if I've given that impression. I would think that if you used a single entry style manifold that it would make no difference, or may even be worse than a correct manifold/turbine housing design.
    The 3T GTE that I drove with a twin entry housing had a custom manifold to suit the twin entry design.
    My car had a manifold made to suit when I ran the single entry CT26.
    I only ever briefly ran the stock manifold and turbo, later I changed to stock turbo with a new manifold, so my experience with the stock manifold is very limited.
  1. 3T Versus 3T GTE conrods
    Last Post: 01-06-2007, 12:59 PM
  4. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
