Results 1 to 15 of 23
Thread: Engine management for 1uz
    Smile Engine management for 1uz
    Hey all, this is my 1st post, just wanting peoples opinions on best engine management system for a 1Uz thats going in my hilux. Its an 02 model with 2.7efi engine currently, a mate has suggested microtech, as they are installed and tuned for around 1500.
    Also are there ever cruises on in victoria for toymods?id be intrested in getting into that sort of thing
    Any thoughts appreciated
    Thanks guys
    Default Re: Engine management for 1uz
    Are you talking early 1UZ or late VVTi 1UZ? NA or Turb or S/C?
    For a good budget package you could go http://www.adaptronic.com.au fitted and tuned for around $1100. Or if you want the works check out the thread with IS200 1UZ VVTi Autronic SM4 for over $3,500
    One persons opinion of 'best' is very different to another persons opinion.
    The 'best' is MoTeC, bar none. However, it probably does eleventy billions things you'll never need.
    For the 'best-bang-for-buck', as pointed out above, look into Adaptronic.
    30DET... The only way. Carport Converter Kyosho's Avatar
    Adaptronic.
    Soarer guys seem to love em for the 1UZ.
    I run one on the R33.
    A mate used to run one on his Honda
    All worked great from every account I've had with them.
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
    Forum Sponsor Conversion King
    Dec 2006
    is that from an engineering, service, adaptability, features or tuning point of veiw?
    trust me there are faults with motec also in there mapping setup but i suppose it all depends on what you want to achieve with it.
    personally i believe autronic would be the best as far as supplying the engine with exactly what it wants, but at the end of the day it doesn't mean shit if some monkey is punching the numbers in.
    easiest thing to do is figure out your budget and find a couple of ecu's that could do the job and then figure out which one is the best for your needs.
    linden
    Ok cool thanks guys adaptronic sounds ok to me, It will be an early 90s front sump 1uz, so just looking for a basic ecu that covers all the important bits. Will just be street tuned with exhaust and extractors nothing fancy so dont need motec. Should push around 160kw hopefully id be happy with that
    Junior Member Backyard Mechanic pisso001's Avatar
    Dec 2006
    Will it be manual?
    Yep definitely manual, im told the standard box will bolt up with correct bellhousing, and should hold if i dont treat it like crap, but with a stronger clutch. Will be keeping an eye open for stronger box as i know it will need replacing sooner or later.
    Can anyone tell me what a minispool does for a diff? someone mentioned this instead of lsd
    Dec 2006
    Minispool will lock your diff, therefore making it illegal. Someone else will explain how.. Go for an LSD mate its not worth the hastle and uncomfortable ride in your lux.. And if you are gonna load it up with gear then you will break stuff axles etc..
    Thanks,
    Chris.
    Quote Originally Posted by nz_farmboy
    minispool = welded diff = bad for road
    Ok will forget the minispool then and hunt for an lsd
    Apr 2007
    If you are keeping the motor pretty stock, why not run the factory computer ? will certainly save you a shit load, & no tuning issues etc .. You cant beat the millions the factory spend on R&D ...
    yea i know i just figure if im going to get serious in the future i may as well start with standalone. Should get me a better tune if i can find someone in vic whos not a monkey, ive heard some shocking stories
    Hit up the adaptronic website for you local rep.
    out of intrest has anyone used linkplus from nz? all my mates over there drive imports, a couple of low 11 sec street cars, and they all use link ecu's and think highly of them
  1. Toyota R Engine History
    Last Post: 02-12-2011, 09:41 PM
  2. MA70 --> JZA70 Conversion
  3. Turbos 101
