Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 91 to 105 of 175
Thread: What size turbo would you use to make 400 - 450 WHP (max) with a 1JZ...
  1. #91
    Forum Sponsor Conversion King
    Default Re: What size turbo would you use to make 400 - 450 WHP (max) with a 1JZ...
    Quote Originally Posted by Draven
    or not be weak
    after your effort the other day i wonder why you even want to raise the boost. i think a deisel gemini with AC and PS would have enough power for you yes, you need to redeem yourself from that petty excuse of a .... well i dont know what you would call that
    i personally dont like running big boost on PULP but its not the fuels fault that it detonates as its the tuners job to ensure that it doesn't by either reducing timing or dumping more fuel in but neither of these are really power productive.
    linden
  2. #92
    Professional Amateur Grease Monkey sil80 1J's Avatar
    Feb 2008
    im just about to put a 3582 on my 1j chasing similar power to this guy and im debating the rear housing...
    can someone give me pros and cons of the .63 and .82 rear housings? i dare say this will help others make up their mind about which turbo to select!
    Sil80 1JZ chasing 400rwkw
    Update: 4/5 the way there on 21 PSI, 350.3rwkw
    http://i112.photobucket.com/albums/n...L801copy-1.jpg
  3. #93
    so are you after 450rwhp or 400rwkw as in your sig?
    Being a sil80 I am assuming it is for drifting?
    Need more details
    QUICKEST 1JZ'S IN OZ
  4. #94
    Junior Member Grease Monkey grim boy's Avatar
    jeff jeff jeff . just drive your girl friends car then drive mine and make up your own mind , lol ,
    Dennis
  5. #95
    Feb 2008
    Quote Originally Posted by grim boy
    Dennis
    i had the stop watch out to see how long it would take you to respond... hahaha
    i will discuss my reasoning behind the thought at a later date away from prying ears...
  6. #96
    Feb 2008
    Need more details
    at the end of the day its going to be drag, street and track, just want a meaty car with loads of power but still response, i know thats a contradiction but ide be happy to max out a .63 rear housing and be happy with the power... but having read some posts ive seen that response doesnt change all that much between the housings and i am running big cams with gears...
  7. #97
    big cams as in HKS 264's, 272's?
    If so, I would be going .8 rear if not 1.06
    If they are 256's, I still think .8 as you may start to outflow the turbine housing in the top end if you are running some big boost.
  8. #98
    Feb 2008
    yeah 264 inlet and 272 ex... thats what i was thinking... ill just deal with the slight loss of response from a .63 and get the mid and top end of the .82
    cheers guys for all your info!!!
  9. #99
    staggered cams are a waste of time, go 272 272, or 264 264
    your going to have to put 28 psi into a 35r to get 530rwhp, your going to need race fuel and a manual; box
    you also going to need a 1.06 rear to get that power, a .8 wont do it
    8.3 et PB 169 MPH PB
  10. #100
    Feb 2008
    Quote Originally Posted by 1JZ.747
    ive seen plenty of examples of .82s and a .63 going over 500rwhp on lower boost and pump fuel...
    will have to see how it goes, ill be sure to put the results up here as soon as i get it running
  11. #101
    you can get any number by putting the temp reader on the exhaust manifold.
    ive seen and owned and driven cars with that setup up, seen them tuned and run to back up the power figures made.
    we can all live in fanstasy land where we all make 400rwkw with minimal mods, but in the real world with true dyno figures it doesnt happen.
    a 2j with with a 1.06 35r will just push 500 rwhp, cams will give it a bit more, but the fact remains that turbo will only flow so much air.
    if you can make 530rwhp it will run 130 mph all day long, hell in a light wieght car like yours it should go 133 134 mph.
  12. #102
    2860lbs or 1300kg race weight, that power should trap 140mph
    edit: that would make it the "fastest" 1j in oz BTW
  13. #103
    still trying to finish ours to get that title
  14. #104
    Junior Member Automotive Encyclopaedia HKS_TRD's Avatar
    May 2006
    Earth Beta
    Todd
    Man the fuck up an buy a 35R
  15. #105
    May 2006
    Earth Beta
    Finally, someone that doesnt dribble shit when it comes to power figures!
  1. Whoops ... 1JZ turbo blown?
    By BabyZ in forum Tech and Conversions
    Last Post: 09-12-2007, 08:21 AM
  2. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 07:13 PM
