Results 1 to 6 of 6
Thread: Head gasket replacement????
    Nov 2007
    Default Head gasket replacement????
    Hi, bit of a noob question. But want to know if a head gasket can be re-used? It is only a couple of weeks old but has been torqued down on the current motor. Motor had BHG, so was replaced but then did a bottom end bearing. So will be taking the head off and putting it on another block. So considered re-using head gasket and applying head gasket copper spray stuff. Thanks
    vic
    Default Re: Head gasket replacement????
    If it hasnt been crushed or fallen apart when removing then yes , spray it with hylomar first then torque it down again .
    Dave
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Is it on a 7M? If yes, why would you risk it?
    MHG yes, normal composite NO
    Apr 2007
    A big fat NO. btw, i have a left over ACL monotorque headgasket if you want it. Came in the gasket kit, but i used a MHG. If you want it it's yours for whatever reasonable price you care to name.
    Tallahassee, FL USofA
    Quote Originally Posted by MX83-maybe
    Any gasket can be re-used, if it's OK. It cannot be reused if it is damaged in a critical spot or the surfaces have been changed.
    If you don't know, don't do it.
  1. thinner head gasket for a 4ac
    By Wedged'86 in forum Tech and Conversions
    Last Post: 09-01-2007, 02:12 PM
  2. Need Info on correctly sealing a copper head gasket with o-rings
    Last Post: 03-11-2006, 08:11 AM
  3. 7mgte head gasket
    By Suprano in forum Tech and Conversions
    Last Post: 22-09-2006, 12:34 PM
  4. Changing 1GGTE Head Gasket
    Last Post: 31-03-2006, 09:26 AM
