Results 1 to 2 of 2
Thread: ST165 tech info wanted
    queensland
    Default ST165 tech info wanted
    I'm chasing someone with a factory workshop manual and/or sales brochure for the ST165. I am chasing this info to finish off an article I'm writing on tuning 3SGTE. I have all the info for later gen 2 & 3 engines which I work on all-day, everyday, but missing this for the early 1st gen ones:
    Injector flow info . found in manual under "testing injectors" it specifies the allowable flow rates when tested for 15 seconds
    Fuel rail pressure regulator info . found in manual under "testing regulator" it specifies the allowable pressures with the manifold pipe connected and disconnected.
    power/torque values. only found in sales brochures or road tests. I would like power and torque. usually specified as "??kw @ ???rpm EEC-nett". this is the value when tested on an engine dyno with ancillaries like alternator connected.
    many thanks, Terry
    GT4 Freak, and Conversion King Squid's Avatar
    Default Re: ST165 tech info wanted
    Terry - http://www.celicatech.com/imagearchi...lltrac_bgb.php
    It is the American manual, I don't imagine they would be too different.
    ST185 GrpA #116
    ST165 GT4 Project Car - Soon with v6 goodness.
    The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
  1. sand blasting info wanted
    By rn-85 in forum Tech and Conversions
    Last Post: 07-10-2006, 10:25 AM
  2. INFO WANTED: W5x close ratio gear kits
    By irishtwincam in forum Tech and Conversions
    Last Post: 03-10-2006, 06:09 PM
  3. 20 valve TB info wanted - measurements
    Last Post: 24-03-2006, 05:02 PM
