Results 1 to 7 of 7
Thread: fitting aftermarket cam gears to 1jz question
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Default fitting aftermarket cam gears to 1jz question
    I have heard that with some of the aftermarket cam gears once fitted, the cover will not fit over the gears. can anyone clear this up?
    Forum Sponsor Conversion King
    Default Re: fitting aftermarket cam gears to 1jz question
    this is true but only for fidanza and some custom made gears, im pretty sure all the jap gears fit behind as they scolop the front face out and have the bolts countersunk / recessed.
    linden
    penrith nsw
    cheers for that
    IM running a Greddy exhaust cam gear... NO problems at all so far
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
    penrith nsw
    Quote Originally Posted by Dieseltrain
    Thats the unit i was thinking of getting
    Fidanza's fit just, put every thing back on as normal but dont tighten the top middle two bolts that go through the coil cover as well. Grab a second pair of hands to pull the cover out with a decent amount of force pressure. Tighten the shit out of the top two bolts. Should be ok now
    I've been doing that to mine with success although I've just pulled the cover out myself then tightened with the same result. Every now and then it might stat to scrape again, just pull and tighten again.
    HTH
    Malicious
    +1 for the Greddy, mine fits fine. Make sure you tighten up the bolts on it VERY tight though.
    244rwkw / 328hp @ 18psi
  1. 1JZ vs 7M alternator useful info and pics
    By Ribfeast in forum Tech and Conversions
    Last Post: 22-06-2009, 04:10 PM
  2. Installation of aftermarket BOV on 1JZ
    By Danners in forum Tech and Conversions
    Last Post: 23-02-2007, 12:35 PM
  3. Installing An Aftermarket Blow Off Valve - 1JZ
    Last Post: 16-09-2006, 06:31 PM
  4. 1jz Aftermarket Ecu
    By thommo in forum Tech and Conversions
    Last Post: 27-01-2006, 09:09 AM
