Indicators and hazards?
I would steer away from the lights being on two different switches cause youll have trouble getting it to work due to the hi/lo being negative switched especially if your running a SPDT relay. Although in factory form it would be quite easily and allow for both lights to be run simultaneously - although i doubt you would need this.
Im pretty sure that the wipers when switched to high run the low winding along with a secondary winding in the motor to increase speed. The single winding is used on its own for low speed.
